Help 06 suddenly died and starting problems...
Did you attempt to immediately start it again after this happened? The above happens after anytime the battery is disconnected from a 2IS model. A second start is needed to kick it over.
I've read about some having faulty ground wire connections or bad ground wires over time. Try removing the battery to inspect the wiring a bit better.
This would also explain why the car stopped while running.
magnificen
31
10-30-18 02:27 PM
