Vibrating Steering
Vibrating Steering
I recently did the following work on my vehicle and while driving home from the shop today on the highway I noticed there seemed to be a lot vibration on the front end. Below is a list of what was done over the last month, (the car was brand new in 2009 when I got it and I really don't want to go back to car payments anytime soon.)
2009 Lexus IS250 AWD
1. 4 new Michellin tires- all balanced
2. New control arms- driver and passenger side
3. New ball joint- passenger side only (apparantly it broke while it was being taken apart and put back together during control arm work), mechanic never mentioned anything about driver side.
4. Wheel alignment- after control arms and new tires
What could be causing this, I take the car to a reputable service center and have never had issues or felt I was "oversold". I won't prentend I know much about the mechanics of a car but I think with that amount of work and money spent it should not be doing that and would just like to have a general idea when I take the car back to the shop.
So in other words he should have replaced the ball joint on the drivers side aswell even though there wasn't an "issue" on that side like there was on passengers side
It's alright if you just replace one side but the other side will break down as well soon due to the pressure of the new one and old one, must be balanced out when it comes to suspension. Shock and Ball Joint should replace in pair.
once it comes to suspension i'm not cheap !
Because he's a man that like perfection of the car, these customers usually have no time they want everything done at once so they don't want to go back and ford, reason why he should replace ball ball joint in pair, you don't have to but you know that other one will break soon right ? leaf spring, ball joint strut and mount and tires should be in pair, it's ok if you dont want to spend money but the time you spend will be more.
The reason for replacing shocks/struts, springs, or tires in pairs is because of the driveability issues that may result from not doing so, not because the other part may "break soon".
Lets try to help the op find out what is causing his vibration, not tell him to replace a part that a mechanic looked at and determined was good.
It's not about being cheap... Ball joints only need to be replaced when they are faulty, this is usually because of excessive movement in the joint, in the ops case he said the ball joint was damaged while being removed from the old control arm. According to your logic he should replace all 4 ball joints (uppers and lowers) because they might "break soon" as well... Heck he should also replace all four control arms, and the rear control arms too, those certainly will "break soon"...
For Lexus IS250 AWD at least mine one, i'm currently have BAD TIE ROD and Rear Alignment toe but the car drives straight, for non-alignment guys they will feel nothing but for me i feel it sloppy on uneven road and shimmy when hit a bump, i also have 2 cracks bushing for lower control arm the steering is kinda weak. Sure you are Pro Mike ! ya sure you can Google or check Youtube Engineer explains, any suspension component worn they will wear out your tires prematurely, do a research before you speak !
For my car i'm cheap because as long as the car drive straight i don't care but the handling sucks bad.
seanmwple
05-07-18 07:15 PM
Bkwindom84
10-03-09 08:27 AM
