DRL on 2006 IS250
DRL on 2006 IS250
Hi, anyone know where I can get continuous power from the time engine starts for Daytime Running Light (DRL) on my IS250?
Thank you
Thank you
IGN2 is where I tapped for my LED DRL's. I switched the DRLs off and now have the LED strips as my DRL.
Thank you so much guys for your reply/advice.
I am new to this therefore may I please request you to send me pictures of what you are referring to (preferably with arrow).
Many Thanks
Many Thanks
I managed to get power to the DRL.
I have a Relay Harness DRL Control, one wire needs to be connected to the low beam headlight so that DRL will dim to 50% when low beam headlights are on. Anyone know what's the best wire I should connect it to? I assume I should connect it to the live wire of the low beam headlight however I don't know where that is.
Finally managed to install it, however not too happy with the DRL LED colour as it doesn't match with my headlight.
Any suggestions how I can make the DRL same colour as headlight?
Headlight is Philips 6000K
Is there any filters I can add to remove blue effect on DRLs?
foam
07-29-12 08:26 PM
