Smog check with code 2757
I have a 2006 is250. Recently the code pops up with the usual vsc and engine light on the dash. The car is due for registration and requires a smog check.
My question becomes : will it pass the smog check with this problem?
Will it pass if I turn the lights off with a scanner right before the smog check inspection?
That code is for the torque converter in the transmission, one of the solenoids is bad.
http://www.autocodes.com/p2757_lexus.html
If you reset the code before going in for the inspection, you probably won't pass because the monitoring system will not be in a "ready" state.
The solenoids are on the inside of the transmission, mounted in the valve body. While some dis-assembly is necessary, I've never done it so I don't know how hard or easy it might be.
