2010 IS250 - Weird Engine Sound After Cold Start
Old 03-14-16, 06:13 PM
joshua28
joshua28's Avatar
Default 2010 IS250 - Weird Engine Sound After Cold Start
Anyone know what the problem is? Started hearing this after cold starts last week. Thanks.
Old 03-14-16, 07:43 PM
MWIS350
MWIS350's Avatar
That's little loud. How the car drive?
Old 03-14-16, 07:58 PM
joshua28
joshua28's Avatar
Drives fine. Sound goes away after a while.
Old 03-14-16, 08:03 PM
MWIS350
MWIS350's Avatar
If no engine code and car drive fine I wouldn't worry too much.
Old 03-15-16, 06:43 AM
Soledad
Soledad's Avatar
I'd guess a belt or pulley. Go get you about 3 feet of 1/2" or 3/4" heater hose from Autozone or car parts store and use that has a mechanics stethoscope to pinpoint the noise being very very careful around the moving parts when you do. Almost sounds like a pulley bearing going bad. Or it could just be a spot on the belt or one of the pulleys that needs a little roughing up with some sand paper or emery cloth.
Old 03-15-16, 01:57 PM
Gville350
Gville350's Avatar
Sounds like a pulley or bearing about to go, AND since it appears to be near the front of the motor I'd definitely be looking at the water pump as being the culprit. These water pumps are notorious for going out; heck, mine did at only 27k miles! The alternator pulley or ALT clutch is also know to be faulty.
rns
Hybrid Technology
12-05-16 02:08 PM
gabzor
09-15-12 07:02 AM
xioix
Maintenance
12-23-11 10:29 PM
lexusben
11-28-10 07:11 PM
sc400123
09-18-09 10:33 AM
Quick Reply: 2010 IS250 - Weird Engine Sound After Cold Start
