Stock OEM rear sway bar size for 2010 IS250 rwd
Does anyone know the stock rear sway bar size for the 2010 is250 rwd is? I am looking to purchase the f sport rear sway bar. Does it come with the bushing and bracket or are those purchased separately?
Keeping it Real
If you buy the rear bar by itself it will come with bushings. It will not come with brackets or end links.
If your car has the factory sport suspension, you will reuse your factory brackets, bolts and end links.
If your car does not have the factory sport suspension, you will need to get the brackets and bolts separately. You will reuse your factory end links.
You will only need new end links if yours for some reason are damages or cannot be removed without damaging them.
Jeff
Jeff
I looked under my car and notice that my car has the one-piece bracket/bushing/sway bar (non suspension) and those parts certainly will not carry over to the fsport rsb.
I just ordered the parts you suggested. Thanks a bunch!
benbuilt4u
Suspension and Brakes
05-28-11 07:09 PM
jaxxx
12-30-10 06:37 PM
