A/C issues. Driver side cold, passenger hot
Old 06-07-15, 05:33 PM
doodoo
doodoo's Avatar
Default A/C issues. Driver side cold, passenger hot
Hello guys, I'm trying to figure out an issue with my sister's car. She has a 2007 is250. Down here in Louisiana it gets pretty hot. When using A/C, the driver side is cold but the passenger blows hot. I was trying to search a bit, what I could find is either the servo motors aren't working, coolant issue maybe thermostat or low coolant, or low freon. She won't be stopping by until Tuesday for me to take a look. I'm going to tackle the easier ones first. What are the correct psi reading for freon on low and high? I read some said 14-16 oz but I didn't exactly see any psi ranges. If low, do I just vacuum it out? Add oil and start fresh? Can you see the servo motors working without removing dash? Any help is appreciated. Thanks guys.
Old 06-07-15, 06:19 PM
laobo979
laobo979's Avatar
Time to charge your AC. I don't know exact pressure but all I did with mine buy the can from autozone follow the instruction for temp outside then charged been good for the last two years.
Motivaties (04-27-23)
Old 06-08-15, 10:23 AM
doodoo
doodoo's Avatar
Ok thanks. I'll try it and see if it is fixed.
Old 06-08-15, 02:19 PM
hirsch2is
hirsch2is's Avatar
Freon low. Toyotas usually have it the opposite way due to the Evan layout
Old 06-08-15, 07:23 PM
nosurprise
nosurprise's Avatar
I had this exact same symptom before. Try to set the AC to the lowest possible temperature to see if it would blow cold air on the passenger side. What happened with mine was that somehow the calibration of what the temperature (or sensor) should be vs the position of the some control/motor is wrong in the passenger side. After I set it and blows cold air, I play around with it and it just goes back to normal after a week I think ...
Edit: turn on Dual air mode and set the passenger temperature low enough to start blowing cold air if possible.
Old 06-09-15, 09:24 PM
doodoo
doodoo's Avatar
My sister stopped by, and I played with settings. Still was same. Bought a can of freon and filled it up a little. It was at 29 psi on the low side at first. Engine was hot and temp outside was 80 degrees. I filled it to 42 psi and everything is working great again. Passenger side and driver side are ice cold. Now my sister wont nag at me anymore
Old 06-09-15, 09:52 PM
laobo979
laobo979's Avatar
Glad it worked out that always a sign that it's needs to be recharged when passenger side warm.
Old 06-11-15, 07:16 PM
Gville350
Gville350's Avatar
That probably means that my '06 is probably due for a hit of Freon. My still gets cold, but not ice cold as my 2014 rental car last week.
bacosta007
ES - 5th Gen (2007-2012)
06-25-19 05:34 PM
kaze
06-25-15 08:40 PM
leeadrian
04-21-15 08:16 AM
6SOARER
01-18-15 11:48 AM
2001gs300
07-04-11 12:56 PM
Quick Reply: A/C issues. Driver side cold, passenger hot
