H11 Xenon HID Conversion - Relay Harness?
Old 09-03-14, 02:10 PM
XenonDepot
Former Sponsor
XenonDepot's Avatar
Rather than flip the connector, this video will help with the proper way to reverse polarity on an HID kit:
Many Lexus/Toyotas require reversing polarity but not all. It is hit/miss if you will need to do it. As for as relay, all Xtreme kits come with a relay but the Xtreme ballast is very low draw and on a Lexus/Toyota using a relay is entirely optional.
John
Old 09-03-14, 08:18 PM
spliff
spliff's Avatar
Thanks John. I flipped the connector around and it still doesn't fire. I assume that the contacts inside the connector are touching the prongs when doing this. Also, the connector that comes with the ballast does not "click" into the headlight connector. Is this normal?
Old 09-04-14, 05:35 AM
XenonDepot
Former Sponsor
XenonDepot's Avatar
Hi,
You cannot just flip the connector as the pins will not fully insert and you will not get a proper connection. You need to physically remove the connectors and reverse their locations to ensure proper fitment. Also, the plug on harness will securely plug into your OE harness just like your stock bulb.
Steve
Old 09-04-14, 06:35 PM
spliff
spliff's Avatar
As I kind of suspected, flipping the connectors didn't help. Bulb still won't fire and the connector isn't the same fit as the bulb. Please see the photo for what I mean, where the HID connector has a wider catch, and it doesn't fit in the groove of my headlight connector and therefore there is no click when pushed in fully.
I've also attached a video of the setup. Is there something wrong with what I'm doing here?
Old 09-05-14, 06:56 AM
XenonDepot
Former Sponsor
XenonDepot's Avatar
Hey,
What is your order number? It looks like you have a 9006 connector and not H11.
Steve
Old 09-05-14, 07:37 AM
jonathanz
jonathanz's Avatar
indeed, for sure look like 9006!
quick way to do this is cut your wires but i don't suggest. that's something I would do.
Old 09-05-14, 07:39 AM
XenonDepot
Former Sponsor
XenonDepot's Avatar
NO - please don't do anything yet. Please send me a PM with your order info so that I can pull up your order. If we sent you the wrong bulbs then I will get replacements out for you.
Steve
Old 09-05-14, 08:14 AM
spliff
spliff's Avatar
Thanks Steve, just replied. Looks like I have a 9005 for some reason?
Glad it's not my mad installation skills that was the culprit!
Old 09-05-14, 10:35 AM
XenonDepot
Former Sponsor
XenonDepot's Avatar
Yes - it looks like a 9005 kit is what was ordered (that would be the high beam bulb).
Steve
Old 09-08-14, 08:41 AM
spliff
spliff's Avatar
Looks like I ordered the wrong kit, but Steve and the gang at XenonDepot have taken care of me. I'll be posting pics and a video review once I receive the H11 bulbs.
Thanks again guys.
Marexus
02-24-11 06:47 PM
dzdg8018
Lighting
01-28-09 08:46 AM
sokeen
11-12-07 10:22 PM
techsc400
Lighting
10-16-05 06:55 PM
4double0
Lighting
03-19-03 12:04 PM
Quick Reply: H11 Xenon HID Conversion - Relay Harness?
