08 IS250 Rattling Sound, ~120k miles
Old 07-28-14, 03:50 PM
corypedia
corypedia's Avatar
Default 08 IS250 Rattling Sound, ~120k miles
As of about 3 or 4 days ago, I'm getting a rattling noise under the hood near the pulleys. I know water pump failures are common (or at least seem like it based on what i've read) but I don't see any of the pink coolant dried up anywhere. No status lights, car runs great, temps are normal...just the rattling.
Thoughts?
Old 07-28-14, 04:31 PM
Ants350
Ants350's Avatar
I say water pump. Mine started out like that than one day turned into grinding noise. Mine didn't leak either when pump went. Mine was covered under CPO.
Old 07-28-14, 04:57 PM
Gville350
Gville350's Avatar
Just because you don't see any coolant crust doesn't mean the water pump isn't bad. The bearing is probably shot, which won't necessarily leak on you. I'd get that looked at or repaired ASAP before it implodes on you.
Old 07-28-14, 04:59 PM
corypedia
corypedia's Avatar
any idea what dealer charge typically is for that? or how hard it is to diy?
Old 07-28-14, 05:08 PM
Serifiyah
Serifiyah's Avatar
I wrote up a DIY on here. Take a look at it before you get raped at the dealer. Lol
Old 07-28-14, 06:44 PM
corypedia
corypedia's Avatar
I'm assuming i should at least take it in and have them confirm its the water pump, right? lol
Old 07-29-14, 09:22 AM
Serifiyah
Serifiyah's Avatar
Yea you can do that. But I'm pretty sure its the water pump. I had that exact same noise with a small leak.
lexixel
07-19-18 07:21 AM
PAVGR
05-27-16 02:35 AM
lexuspaaji
02-25-15 12:42 PM
wtfsajayte
Performance
15
11-15-13 04:48 AM
sethjon
03-14-11 06:58 AM
Quick Reply: 08 IS250 Rattling Sound, ~120k miles
