Advice Please... I May Have Scared Myself Away...
Keep in mind that postings on this forum are not the results of a scientific poll. It is much more common to read about problems that people have, because this place is an awesome resource to get resolution of an issue, and/or arm yourself with information to give to the dealer. Without it, I never would have known about all the TSIB's that I got resolved. On CL, we all knew about the carbon build up issues way before the CSP letters went out. Just because there are a lot (and really, how many is "a lot" when they sell 1000s of these cars) of CL posters that cite problems with the nav screen, does not mean that the screen is "prone to fail"--it may must mean that a small number of people are looking for a low cost solution on CL. No one is going to start a thread entitled "My Nav Screen is Just Fine" -- when you only read about problems, it skews the belief as to whether it is "common" or "rare".
As to the IS250 being the most unreliable Lexus per Consumer Reports--this is just not true. Every year, CR lists the IS250 on its recommended list for compact luxury sedans. In the April '13 car issue, it has has an 84 rating (out of 100), and is 5th on the list behind the G37, 328i, C250 and TSX. I'm looking at the year-to-year chart now for '07, and the Audio System is listed as much below avg, Engine Minor and Engine Major are listed as avg (I might assume because of the carbon build up issues), and brakes and trim are also listed as avg. Everything else is listed as above avg, and overall, the car is rated as above avg for that year.
The new 14 IS took a huge hit in CR's ratings, though.
They also do not distinguish between the 250 and 350 in their ratings. Really? Two different engines with different potential issues with each and we're going to just consolidate the data into one rating?
So, I just don't trust them anymore. I suspect the noted engine problems relate to the carbon build up issue. There was a design change around mid 2010 which solved this issue, and I know Lexus was retrofitting the changes free of charge for a while in vehicles that had the problem. I'm not sure what the current status of that is, you could learn more about it here on the forum.
If I were you, I would check two things: (1) has the carbon build up issue been fixed on that particular car? and (2) if not, will you be able to get it fixed at no charge if you buy?
What I wouldn't do is buy a car that has a known issue, then foot the bill for the change for it yourself. The dealership will know if the engine fix has been done to the car or not.
Litespeed
04-19-07 05:54 PM
