How do I change the default navigation screen?
I can not figure out how to change the default navigation screen. Anytime I get off my phone it defaults to the "map." Or if I backup the backup screen will come on and then it will default back to the "map." I would like it to default to the audio screen.
^^ that...or you can just not agree to the initial disclaimer screen by allowing the screen to time out which will automatically revert to the climate or audio screens (usually what it was on the last time) and then when you come out of reverse or take a call it won't switch to the map to start with, it will just go back to the audo screen or whatever other screen you wanted it on. Then when you are ready for the map...hit the map button and tap "agree". That's the only way i know of without hacking the system, seems like i read somewhere you can hack the system so you don't have to get the disclaimer on start up. Anyways, hope that helps....when i get not broke i'm going to just get that VAISTECH unit for Android and be able to do everything i would want to do without any issues (hopefully).
https://www.clublexus.com/forums/is-...and-video.html
^^That should be a good start
rscpa
RX - 4th Gen (2016-2022)
20
05-20-22 06:37 PM
