2009 Lexus is250
Old 05-27-12, 03:26 PM
250Lexus57
250Lexus57's Avatar
Default 2009 Lexus is250
Delete delete
Old 05-27-12, 05:36 PM
LDNN
LDNN's Avatar
Don't have any idea what could have caused that but I hope they at least gave you a loaner.
Old 05-27-12, 06:12 PM
MikeyK02
MikeyK02's Avatar
A) did you have your TSB's done on that car since owning it
B) bad coil pack
Old 05-27-12, 06:16 PM
gemini1
FNM President
gemini1's Avatar
Dang brah, that sucks!
At least it's under warranty and your putting miles on the loaner car not yours!
Hopefully, you get it back so you can cruise the streets of hawaii again.
Old 05-27-12, 07:28 PM
IS2FIFTY
IS2FIFTY's Avatar
good thing its still under warranty, I haven't really heard of anything like this happening....
Old 05-27-12, 08:08 PM
250Lexus57
250Lexus57's Avatar
Thanks people yeah I got a loaner a brand new 2012 is250 it didn't need the tsbs done that's what Lexus said it was all fine but 3years later bam car started making a ticking noise and then lights came on and now it's misfiring does the carbon build up cause misfiring?
Old 05-27-12, 08:29 PM
RWDorGTFO
RWDorGTFO's Avatar
I don't believe the carbon buildup and your misfiring issue can be directly related.
Old 05-27-12, 11:39 PM
KillaIS250
KillaIS250's Avatar
Yes, the carbon build up DOES cause misfiring.
It's one of the requirements/symptoms under the TSIB. A misfire code must be present.
Old 05-28-12, 05:34 AM
iRyan
iRyan's Avatar
Hmmm I've never heard of that happening but I can get it has to do with the carbn build up...but hey u getting basically a new engine
Old 05-28-12, 06:07 AM
slimjimtel
slimjimtel's Avatar
Yes, carbon on your valves can cause misfiring. My MINI had it done due to these cars having excess buildup as well. BMW/MINI does a Walnut blast...they shoot crushed up walnut shells into the valves to clean them. They charge about 400.00 to do it. Not sure how Lexus does their carbon buildup cleaning.
But to answer the question, YES carbon buildup will cause misfiring, usually when the engine is cold. Once it comes up to temp, it tends to settle down.
Old 05-28-12, 05:25 PM
250Lexus57
250Lexus57's Avatar
Thanks people really appreciate the comments and your times any other suggestions that will cause this
Old 05-29-12, 07:57 PM
250Lexus57
250Lexus57's Avatar
So got the call today about my Lexus to pick it up and went to pick it up and they told me they changed the short block and they rebuilt the cylinder head and they told me it was caused by carbon buildup and that it got bad in the block that it scored the walls of the block so they had to replace the short block but got my car back and they didn't even put gas in it and washed it..dropped car off to them. With a full tank of gas and now it's under half tank...and they did the recall for the fuel pressure and carpet so suppose to at least wash my damn car..o wells..Really happy though no sound from engine and no cel light they even had to swap out my battery now time to get some suspension and drop it what kind suspension do u guys recommend for the rwd 09 is250 let me know mahalo thanks for the help guys really appreciate it.
Kapitanemo
03-20-17 01:00 PM
CassieB
12-17-16 11:30 AM
IS250Josh
02-10-14 09:30 PM
dozier08
05-05-06 08:28 AM
Quick Reply: 2009 Lexus is250
