is350 vs g37s
yea i can see with the times you put up a good point. i had alot more mods on my g37s so most the time the is350 only had exhaust so who knows maybe cuz i had more aftermarket parts but never stock vs stock .
we will see when he post the after but from the times you can see it will be close
Let's say I ran a 13.2 on my IS350 and my friend ran 13.5 in his G37s. That is about 2-3 car length. So that is not really that close.
1 second on a 95 MPH vehicle is about one car length.
You sure about that?
Also, don't forget to disable your traction control(hold down vsc button for 5 sec.) Here's a tip I found from one of the members. "The best ET I managed using Dynolicious was a 13.3, and that was with TRAC off, going about 70% or so throttle off the line and smoothly applying full pedal at around 20 mph or so."
remove ur spare tire and some junk in your car, make you car a little ligther and ur probably take him east..but like what most people say...its the driver..g luck..
Yes. Google it.
And when racing from a dig be sure to leave your car in ETC normal (NOT power) too. That's interesting about the 70% throttle suggestion. The last time I was at the drag strip I found the best results from launching full throttle at about 1500 RPM. I'll try it next time.
