DIY - Black Window Trim
Old 04-09-15, 10:09 PM
  #31
bastizdu
bastizdu's Avatar
Originally Posted by ApokC
I took off my chrome because I have a red and black theme on my car. Chrome looked out of place.
Im actually even vinyl wrapping my door handles black too
I have had this dipped for about 3-4 months now, no problems. Handles car washes fine
Looks good I plan on doing mine soon as we'll. did you strictly dip only the chrome? Or the whole window trim molding?
Also did you dip the L on the steering wheel? Pics?
Thanks
Old 04-10-15, 06:34 AM
  #32
Zynthe
Zynthe's Avatar
Thanks for the DIY. My OEM trim is starting to peel, so im gonna have to do this once the rain stops in my area.
Old 04-10-15, 07:08 AM
  #33
JDMToyotas
JDMToyotas's Avatar
Originally Posted by jnguyen87
whats wrong with the chrome around the window..It ISS a lexus..
I agree. Luxury car... Makes the car appear cheaper in my eyes with the black out trim. Like a mod u would see on a Civic or something.
Old 04-10-15, 07:46 AM
  #34
Zynthe
Zynthe's Avatar
If someone has tinted windows the chrome trim might not work as well as blacked out trims.
To each their own....
Old 04-10-15, 08:18 AM
  #35
huyz13
huyz13's Avatar
you should check out the black vinyl tape that some members have used, including me. I got it from the website that sells Mini parts. forgot which Gen you need to buy (search). holds up very well and is removable if needed.
http://www.outmotoring.com/mini-coop...tline-kit.html
Old 04-10-15, 08:28 AM
  #36
Zynthe
Zynthe's Avatar
Hey thanks for the link.
Ill def check this out. Will this product cover all the chrome around my windows or will it look OEM?
The link you provided is for mini coopers. Will this still work on the IS?
Old 04-10-15, 08:58 AM
  #37
getafewliv
getafewliv's Avatar
I had good luck with this product:
http://www.canadiantire.ca/en/pdp/tr...l#.VSfy9fnF-gY
Easy to use and one roll was enough to do all the window chrome.
Old 04-10-15, 09:01 AM
  #38
Zynthe
Zynthe's Avatar
From a scale of 1-10, how hard was this install for you?
Old 04-10-15, 02:04 PM
  #39
getafewliv
getafewliv's Avatar
A 2? If you have ever put tape on something, that's about the extent of it.
Now, to do a quality job, that requires more time and patience. I may have to redo my driver side at some point.
First, I started by cutting the tape in half (length ways) since it's twice as wide as needed. Then clean the trim pieces well and finish it off with a wipe of some rubbing alcohol.
I found that one edge, I could line up and the other side I would slide my finger nail along and it would push it into the groove and slice the material as well, allowing me to peel off the excess.
Two things to note, if it's too cold (I started doing the work in the cold parkade) the material will be a bit brittle. If it's too hot and in direct sunlight, that isn't good either. The material may shrink a bit when it cools down, exposing chrome. Try not to stretch it when you apply it.
Old 04-27-15, 08:18 PM
  #40
jgoorn
jgoorn's Avatar
I was thinking of doing my wheels with the gunmetal gray on an 07 IS350 with 18's. Especially because of this.
Old 04-28-15, 11:03 AM
  #41
whosjustin
whosjustin's Avatar
how many coats did you do on the trim?
Old 04-29-15, 07:11 AM
  #42
Tanoshii
Tanoshii's Avatar
I need to do this. Hopefully it'll get a bit warmer out here and I can get this done :3
Old 04-29-15, 07:08 PM
  #43
mrrhr4
mrrhr4's Avatar
I ended up taking off the black electric tape like trim on all 4 windows looks fine ill post pics
corradoMR2
NX - 1st Gen (2015-2021)
11-19-15 11:37 AM
itsivan
05-30-13 07:16 PM
96817isf
IS F (2008-2014)
08-01-11 02:46 PM
edgeucated
04-08-10 05:51 AM
Xeeeeeem
GS - 1st Gen (1993-1997)
32
01-01-08 03:02 PM
Quick Reply: DIY - Black Window Trim
