how do I remove this? (rear dome light and sharkfin)
Old 10-06-10, 09:05 PM
UmattWayO
UmattWayO's Avatar
Default how do I remove this? (rear dome light and sharkfin)
I was told that if i remove this plastic cover from the headliner, i can gain access to the shark fin so I can unbolt and remove it.
Btw, I found a way to take off that lens cover without prying it and denting the plastic. I used the suction cup from the GPS holders and put it on the cover, then pulled out. Worked like a charm and no damage. Too bad I figured out this method AFTER I dented it..... Whatever, whats done is done.
Anyway, if anyone knows how to remove this thing.. please tell me.
Thanks,
Matt
Attached Thumbnails how do I remove this?  (rear dome light and sharkfin)-img_0587.jpg
Old 10-06-10, 09:10 PM
mrdj
mrdj's Avatar
hey, just wanted to comment on that suction cup.. nice tip! Thanks
Old 10-06-10, 09:15 PM
racerboi07
racerboi07's Avatar
hold it on both sides and yank on it like there is no tomorrow.. it will hurt your fingers and dont be scared to hurt it.. just yank.. it will come out..
Old 10-06-10, 09:18 PM
ohiois350
ohiois350's Avatar
I think you have to pry the whole thing off?
Old 10-06-10, 10:07 PM
UmattWayO
UmattWayO's Avatar
are you sure I just yank it out like theres no tomorrow?
If i damage the headlining I'm gunna go kill something. =[
I tried this morning but it didn't seem to budge.
Old 10-06-10, 11:45 PM
DEMIK
DEMIK's Avatar
u gotta pull down on the trunk side and then pull towards the trunk at the same time
Old 10-07-10, 12:15 AM
UmattWayO
UmattWayO's Avatar
thanks a bunch!
really helps!
Old 10-07-10, 10:33 PM
racerboi07
racerboi07's Avatar
yeah just yank on it.. i was scared to but i got it finally..
Old 10-07-10, 11:00 PM
relaxfoo
relaxfoo's Avatar
does it really give you access to the bolt for shark fin???
Old 10-08-10, 11:58 PM
UmattWayO
UmattWayO's Avatar
I guess I should let you guys know, if case anyone wants to unbolt the shark fin.
Thanks to demik ^^^, i was able to take that thing off.
Once it's off, the bolt holding the sharkin is located slightly further in towards the trunk direction. So it isn't directly under the dome light. Just pull the headliner slightly down, and you will be able to access it.
The sharkfin is only held down by 1 bolt (huge bolt) and 1 wire. So just unplug and unbolt. After thats done, there is 2 clips thats holding the sharkfin into the roof, so just use something to depress those clips and have someone pull the sharkfin out for you from the outside. There is not glue or anything holding the sharkfin onto the roof, so no worries. it's strictly unbolt and take off.
hope this helps clarify some things for those who want to remove their shark fin. I had vinyl put on the roof and sharkfin afterwards.
Matt
Attached Thumbnails how do I remove this?  (rear dome light and sharkfin)-img_0585.jpg
akkord
03-03-20 02:36 PM
tsxnbp
06-19-15 04:25 PM
mbz560
10-29-12 08:55 PM
PlatinumIS
12-25-09 05:14 PM
HKGS300
10-21-03 03:58 PM
Quick Reply: how do I remove this? (rear dome light and sharkfin)
