Side mirror cracked
Old 09-20-10, 09:26 AM
DoughBoy
DoughBoy's Avatar
Default Side mirror cracked
I cracked my driver side mirror while replacing the puddle lights. I was kinda in a rush and put too much pressure Can just the mirror be replaced or will I have to replace the whole side mirror assembly? This is for a 2010 IS 250.
Old 09-20-10, 09:48 AM
CCM03
CCM03's Avatar
Most likely you'll be able to replace just the mirror piece. Do you have a picture to show?
Old 09-20-10, 12:31 PM
DoughBoy
DoughBoy's Avatar
Here's a pic of the mirror. I noticed that there are two wires connected to the back of the mirror. Can those be disconnected from the mirror or is it part of a harness? Do the puddle light, motor and mirror wires all go to one connector? Asked the parts dept at dealership this question but they couldn't give me a definite answer. I didn't pull the door panel to investigate, I was already bummed from the cracked mirror. Any info is appreciated.
Old 09-20-10, 02:15 PM
516IS
516IS's Avatar
Where's the pic?
Old 09-20-10, 06:58 PM
2IS_Girl
2IS_Girl's Avatar
Looks like only the mirror needs replacing. All of the wires can be reconnected. If you can, go to a local junkyard and find a spare mirror. Otherwise, it will run you $100+/- from the dealership.
Old 09-20-10, 09:06 PM
DoughBoy
DoughBoy's Avatar
Thanks for the info. I disconnected the leads from behind the mirror. Those connectors look deceiving because it's covered with some sort of black insulation that makes it look like one piece with the mirror. Just called dealership and they have it in stock.
Old 09-20-10, 09:08 PM
nmpeter
nmpeter's Avatar
It's just the glass that needs to be replaced. The dealer charges a LOT for these mirrors.
Old 09-20-10, 11:24 PM
DoughBoy
DoughBoy's Avatar
The cheapest I could find was an auto glass shop that could get it for 50 bucks but had a 3-4 week lead time on it. I can't wait that long. Dealer is just a shade above 100 bucks and in stock which is ok with me.
Old 09-20-10, 11:28 PM
fknISC808
fknISC808's Avatar
Ouch! hope you get that taken care of. looks like driver side?
OT: is that you "DoughBoy" from Kalihi?
Old 09-21-10, 12:12 PM
2IS_Girl
2IS_Girl's Avatar
OP: Keep in mind that you can also replace your puddle lights without removing the mirror, as well. Use the switch inside the car to adjust the mirror all the way to the bottom and then all the way to the right (repeat for every side) and use a small screwdriver to remove all of the screws. This method may take a little bit longer, but it leaves no room for error in breaking the mirror.
Old 09-21-10, 08:58 PM
DoughBoy
DoughBoy's Avatar
Picked up and replaced mirror on monday. Chalk this one up to lessons learned, DON'T rush.
I'm from Kapolei. Btw was that you going up Houghtailing today around 330ish?
Old 09-21-10, 09:04 PM
DoughBoy
DoughBoy's Avatar
Saw the method you mentioned in another thread but chose to do it the other way. I was successful changing out puddles to leds the first time, picked up new flanks and not so lucky the second time.
Old 09-21-10, 10:37 PM
fknISC808
fknISC808's Avatar
oh, my boy from kalihi, we call him DoughBoy... haha. Yeah that was me, I noticed you and shaka'd then almost hit that stupid truck in front of me because he was going redline and didnt signal.
Old 09-22-10, 09:27 PM
DoughBoy
DoughBoy's Avatar
Sucks when people don't signal...it's like they expect you to read their mind!
Pearlpower
09-04-22 03:25 PM
pman6
06-25-16 04:22 AM
francis123
07-12-14 04:04 PM
zackteee
12-01-13 09:42 PM
BADFNZ
02-15-10 02:12 AM
Quick Reply: Side mirror cracked
