Dealer valve recall and TSIB's
I am about to take my 2006 IS350 to the dealer for the 1st time (bought 5 mths ago) for the 2 recalls- pedal and valve. I have been reviewing the TSIB's-
Am I missing any? (these are ones that I am experiencing)
EG017-06 Sulfur odor
NV006-07 Rear View mirror shake
NV003-06 Instrument panel rattle
AU001-07 Aux port noise
SS003-05 CD Skips
EG019-07 Engine knock/rattle at start up (could someone email me the audio file with the noise if they had a chance to record it? dixieman47@gmail.com)
Done or not needed (front brake pads, fuel line, seat belt,)
Question- I am almost due for an oil change, does any of the repairs above do an oil change?
Thanks for your help...
SS003-05 CD Skips
Super Moderator
Are you sure your car is still under warranty? Almost of of the '06s are more than four years old now. The rear view mirror shake, instrument panel rattle, aux port noise and CD skip TSIBs are only covered if you are still under your 4 year/50k bumper-to-bumper warranty.
You forgot the seat squeak TSB...the dealer will perform this regardless of noise or not. It's when you make turns, and the lower left section of the seat (by the power buttons) creaks and squeaks. The remedy is they have to remove the seat and cut about a forth off a series of plastic pins that stabilize the seat. Search for the TSB number, as its well worth fixing!
I have the extended warranty as well, but upon careful reading of it I do not think TSIB's are covered specifically. It may be up to the dealer, but I think you'll get some pushback on some of those TSIB's. As other's have said, unless you are experiencing the problem they won't do the work. An actual recall; valves springs, fuel rail, pedals, etc will naturally be covered.
To be sure you need to verify with the dealer before they do the work.
Thanks for the info! I found this during my search-
TSB Number & Issue Date TSB Title
SSC9LG OCT 09 Recall - Floor Mat/Accelerator Pedal Interference
SSC9LA JAN 09 Recall - Fuel Rail Replacement
SSC9LC JAN 09 Campaign - EPS Steering Gear Replacement
SSC9LB JAN 09 Campaign - Rear Brake Caliper Inspection
SB0188-09 DEC 09 Engine Controls - A/F And O2 Sensor Identification
SB0187-09R1 DEC 09 Interior - Floor Carpet Grommet Serviceability
SB0184-09 DEC 09 Audio/Interior - Creak/Pop From Dash/Radio Area
SB0169-09 NOV 09 Audio System - Noise When Using Auxiliary Devices
SB0155-09 NOV 09 Brakes - Excessive Brake Dust On Front Wheels
SB0085-08R1 OCT 09 Engine - Serial Number Locations/Identification
SB0084-08R1 OCT 09 A/T Serial Number Identification/Locations
SB0151-09 OCT 09 Suspension - Rear Suspension Clicking Noises
SB0153-08R1 OCT 09 A/T - Reman A/T Serial Number Location/Identification
SB0072-09R1 AUG 09 Instruments - Inside Rearview Mirror Vibration
SB0090-09 AUG 09 Audio System - Satellite Radio Inop Until Ign. Is Cycled
SB0161-08R1 JUN 09 Keyless Starting - Intermittent No Crank/No Start
SB0068-09 JUN 09 A/C - Odors Noticed Intermittently
SB0154-08R1 MAY 09 Tires - Pressure Compensation/Adjustment
SB0060-09 MAY 09 Wipers/Washers - Wiper Blade Maintenance/Cleaning
SB0044-09 APR 09 Engine, A/T Controls - MIL ON/DTC P0751 Set
SB0015-09R1 APR 09 Brakes - Front Brake Squeal/Squeak In Cold Weather
CRIB173 APR 09 Paint - Refinishing Information
SB0025-09 MAR 09 Tire Monitor System - 'Lost Communication With ECU' Mssg
SB0023-09 MAR 09 A/T - Fluid Level Inspection/Temperature Ranges
SB0121-08R2 MAR 09 Brakes - Excessive Brake Dust On Wheels
CRIB172 MAR 09 Body - Bumper Component Repair
SB0017-09 FEB 09 Body - Moonroof Auto Close Function Inoperative
SB0174-08 DEC 08 Steering/Suspension - Vehicle Pull Repair Supplement
SB0156-08R1 DEC 08 Engine - Brief Engine Knock/Rattle On Cold Start Up
SB0167-08 DEC 08 Restraints - SRS Lamp ON/DTC B1861 Set
SB0125-08 OCT 08 Cruise Control - Check PCS Message/DTC B2056/P1572
CRIB170 OCT 08 Body - Plastic Bumper Refinishing
SB0091-08R SEP 08 Engine - Valve Timing Procedure
SB0090-08 SEP 08 Body - Upper/Lower Windshield Tick Noise
CRIB164 SEP 08 Vehicle - Replacement VIN Plates/Certification Labels
SB0083-08 AUG 08 Body/Frame - Protective Wax Coating Information
SB0047-08 JUL 08 Lighting - HID Headlamp Diagnostic Tips
SB0044-08 JUL 08 Interior - Instrument Panel Rattle
CRIB167 JUL 08 Body/Interior - Trim Removal & Installation
SB0036-08 JUN 08 Keyless Entry - Smart Key Battery Diagnostics
SB0031-08 JUN 08 A/C - Interior (Cabin) Filter Replacement
SB0026-08 MAY 08 A/T, M/T - Alignment Pin Service Precaution
SB0024-08 APR 08 Brakes - Rattle From Vehicle Rear on Bumps
SB0021-08 APR 08 Engine - Cylinder Head Cover Baffle Precautions
SB0015-08 MAR 08 ABS/TCS - Zero Point Calibration Information
CRIB165 MAR 08 Body - Acid Rain Paint Damage Prevention/Repair
AC003R-07 FEB 08 A/C - Driver/Passenger Front/Rear Carpets Wet
CRIB163 FEB 08 Body/Frame - Sealing Hem-Flanges & Body Seams
CRIB161 JAN 08 Body/Frame - Collision Damage Repair Precautions
CRIB160 DEC 07 Restraints - SRS Service Precations
PG007-07 NOV 07 Vehicle - Replacement VIN Plate Information
CRIB158 OCT 07 Body/Frame - Panel Adhesive Information
PA001-07 AUG 07 Body - Exterior Color/Scratch & Acid Resistant Paint
SS006-07 AUG 07 Electrical - Absorbed Glass Mat (AGM Battery Information
SS005-07 AUG 07 Restraints - SRS Component Disposal
CRIB155 AUG 07 Body/Frame - Sectioning Guidelines
CRIB156 AUG 07 Electrical - SRS and HV Wiring Repairs
TC008-07 JUN 07 A/T - 'World Standard' Fluid Information
EG015-07 JUN 07 Engine Controls - Bank 1/Bank 2 O2 Sensor Identification
EL003R-07 MAY 07 Navigation System - Talk Back System Malfunction
PG001-07 MAR 07 Tire Monitor System - Diagnostic Tips
EL001R-06 MAR 07 Smart Key(R) - Repair Manual Supplement
TC002-07 MAR 07 Drivetrain - Driveshaft Replacement Precautions
EL002-07 FEB 07 Air Bag System - Repair Manual Supplement
EL016-06 DEC 06 Starting System - Vehicle Start After Battery Depletion
PG001R-06 NOV 06 Battery Maintenance for In-Stock Vehicles
BO012-06 NOV 06 Restraints - Seat Belt Extenders
SU001-06 OCT 06 Suspension - Shock Absorber Replacement Criteria
PD039-06 AUG 06 Tire Monitor System - Valve/Sensor Activation Procedure
PD034-06 AUG 06 Body - Front Spoiler Installation Instructions
PD030-06 AUG 06 Body - Power Window Initialization Procedure
PD031-06 AUG 06 Instruments - Compass Calibration Procedure
NV001-06 MAY 06 Interior - Front Seat Squeaking Noise
AU001-06 APR 06 Audio System - Quick Reference Troubleshooting Guide
Just go to http://drivers.lexus.com/lexusdrivers/home and register. It will tell you your recalls on the vehicle that you need to do and all your service history done at Lexus.
Super Moderator
3KGTVR4
10-14-09 02:12 PM
