Fender Liner Rubbing
Old 04-21-10, 11:52 PM
anonymous1
anonymous1's Avatar
Default Fender Liner Rubbing
I've just installed some 19's on my IS and now I'm getting little rubbing when I'm at full lock turning left and I go down an incline. I think its rubbing against my fender liner. I've read up on how to do the heat gun technique but I'm not really sure where to remold the liner. Is there a common place where the fender liner needs to be remolded to prevent rubbing?
In case it helps, I'm running 19x8.5 with a +38 offset and 235/35/19 tires in front. I'm lowered to about a 1 finger gap in front.
Thanks for your help!
Old 04-22-10, 12:03 AM
Mv350
Mv350's Avatar
take wheel off, look where your rubbing, youll be able to tell... then heat up fender liner with heat gun until super hot, push in with some thing(not your hand, even with gloves you will burn yourself) then when pushed in spray with ice cold water and itll harden. repeat in every are you rub.
Old 04-22-10, 12:07 AM
anonymous1
anonymous1's Avatar
I've tried looking at areas, but I think the rubbing is so infrequent that it's not leaving much of a mark, I was sort of hoping that there was a common area that rubs...
Old 04-22-10, 12:10 AM
llamaboiz
llamaboiz's Avatar
if your rubbin ISNT leaving a mark, your not rubbin enough
*really thou, dont worry about it, if theres no mark, its soooooo minor no worries*
Old 04-22-10, 12:11 AM
GiantsFan
GiantsFan's Avatar
Im rubbing like that too.... (There is a hole now lol)
Since I have no access to a heat gun im thinking of just cutting that area away... its a pretty small pot, like a 1X1 inch area that rubs...
Old 04-22-10, 09:20 AM
Mv350
Mv350's Avatar
take a blow dryer, it jsut takes longer.
but if it not leaving a mark i would worry about it. i have big holes
Old 04-22-10, 09:40 AM
mdgrwl
mdgrwl's Avatar
my fender liner looks like it was thrown into a fire, lol.
Old 04-22-10, 10:03 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
heat gun should solve the problem.....
Old 04-22-10, 10:57 AM
IS-SV
IS-SV's Avatar
I have infrequent and minor rubbing with front 19x8.5 35 wheels, 235-35-19 tires. I am not bothering to to heatgun liner, it's so minor.
Old 04-22-10, 01:02 PM
LexHes
LexHes's Avatar
Same here. There's actually a little hole in my fender liner as well
Hopefully theres not rust under the liner!
Old 04-22-10, 02:34 PM
Proper 350
Proper 350's Avatar
mine too and im sittin on stockies
Old 04-22-10, 04:26 PM
AK-47
AK-47's Avatar
ask a friend to look out for it while your make a back turn, thats how I found my, is right on the middle. a heatgun will do the job.
Old 04-22-10, 04:35 PM
JoshIS408
- - G T V I P - -
Forum Moderator
JoshIS408's Avatar
I rubbed too when i put my 19"s on at full lock. The palce i was rubbing was the front driver side wheel. You need to heat gun and push back the plastic closest to the driver seat. I did both sides and im rub free
Old 04-22-10, 06:26 PM
Lexasaurus
Lexasaurus's Avatar
Hahahaha, nice.
Old 04-22-10, 07:46 PM
6Sp33d
6Sp33d's Avatar
.....you guys still have your fender liners on?
lol jk, mine has been slaughtered forreal tho.
Quick Reply: Fender Liner Rubbing
