IS350 Spark Plug Change...Toyota told me 100k miles
Old 03-29-10, 07:53 PM
edgeucated
edgeucated's Avatar
http://www.densoiridium.com/faq.php
it actually rates it up to 120k. however im in total agreement with you kurtz, i would never let my plugs go for that long
Old 03-30-10, 01:08 AM
uz07lex
uz07lex's Avatar
There is no way im letting my plugs go 100k before I change them. I changed my plugs at 55k miles. I noticed the engine ran a little smoother and plus I got to inspeck and make sure things are going ok in the cylinders.
Old 03-30-10, 06:32 PM
teracon
teracon's Avatar
I did mine 2 weeks ago. The cost for me was $117 + $10 for the wrench extension. The dealer wanted to charge $415.
It took me about 2 hours because I had to drill the head off from one of the hex bolts that holds the large black box that sits under the removable top engine cover.
I will say that the 3 on the passenger side was the easiest (on the IS250). It took about 15 minutes to replace. The 3 on the driver side is a SOB. When I took out the plugs, there were past their time (68k). I have noticed better response, but MPG's are a little off. It could be due to my heavier than usual right foot.
Old 03-30-10, 07:39 PM
juice14
juice14's Avatar
Why not change them before, you will prally only change them once while you have the car, so might as well change them and use some freshies before u sell it. 100k miles is alot for most people
Old 04-01-10, 07:42 AM
MJB_LEX
MJB_LEX's Avatar
I have 50K on mine. I took it in and asked them to flush and replace the transmission fluid (which is also transfer case fluid on my AWD), flush and replace the coolant, and to replace the spark plugs. They refused to perform ANY of these services. I told them that the car is going to see alot less usage because I bought another car (so I won't be driving the IS much) and that I wanted to have all the fluids and plugs fresh. Still, the technician refused. They said the car needs no service.
They told me 100K for the Transmission fluid and the coolant and 120K for the spark plugs!!
I still think that at a minimum the transmission fluid should be changed.
Any advice?
Old 04-01-10, 07:47 AM
4TehNguyen
4TehNguyen's Avatar
the transmission is sealed, that's why they refused. There's a reason why you don't see change transmission fluid in the maintenance schedule. Coolant is 100k miles also
Old 12-11-11, 06:04 PM
DRivera250
DRivera250's Avatar
sorry for resurrecting this thread. but it seems like there is a big debate. I had two different service advisors tell me 60K and 120k for spark plugs. my gas mileage is about 25 on avg. mostly highway miles. I'm at 68K right now.
Old 12-11-11, 06:21 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
You already posted a thread about this here: https://www.clublexus.com/forums/is-...k-or-120k.html
Were your questions not answered?
Jeff
Old 12-11-11, 06:53 PM
jbjones85
jbjones85's Avatar
60k.... its in the owners manual.
Old 12-11-11, 08:48 PM
p0lo8
p0lo8's Avatar
Change them at 60k intervals. I changed mine after 60k and they didn't look good at all.
Old 12-12-11, 10:03 AM
DRivera250
DRivera250's Avatar
Jeff
no they were not answered. if supposedly qualified lexus service advisors are telling lexus owners to wait to change at spark plugs. I thought I might have had a isolated incident. but now i know it is not the case.
Old 12-12-11, 10:25 AM
Kurtz
Kurtz's Avatar
Many of the service advisors are a lot less qualified than you give them credit for (witness the people who have had their staggered wheels rotated at a "qualified" dealer for example- or the one guy who had one suggest his issue might be his power steering pump- a part that does not exist on the car).
I can't figure out why you want to take the occasional isolated ignorance of a dude at a local dealership over what it written down in the manual by the people who actually designed and built the car
Old 12-12-11, 10:42 AM
DRivera250
DRivera250's Avatar
Touché! thanx guys.
flynryan
02-08-17 04:01 PM
P128sniper
03-31-14 11:47 AM
blanquitom
04-21-11 08:43 PM
i3urton
Performance
16
12-02-07 10:01 AM
tantheman
10-30-02 01:53 AM
Quick Reply: IS350 Spark Plug Change...Toyota told me 100k miles
