Need info on the OEM 17" Wheels
the 17 inch 10 spokes are not staggered and do not come staggered on the awd due to the awd.
if you are talking about the 18's that are a 5 spoke split design that are most commonly seen on IS350's and rwd 250's those are 18x8 +45 up front and 18x8.5 +50 in the rear. i believe those offsets are right or should be very close to that.
AS3.0cl is correct, I just removed my non staggered is250 awd rims and they were a 17X8 with a 45 offset. AWD cannot have a different offset on any axle or it will ruin the driveline. Make sure to keep all 4 same wheels and tires on all 4 axles.
Received 1,064 Likes
17" IS250 10-spoke aluminum alloy wheel
The only thing that comes staggered on the IS250 RWD are the tires...
225/45VR17 all-season tires front
245/45VR17 all-season tires rear
The wheels, as mentioned, are 17x8 with a 45mm offset on all 4 corners.
The IS250 AWD come with 225/45VR17 all-season tires on all 4 corners. (same wheels)
Joe Z
Joe Z
