Old 12-15-14, 01:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
DIY aftermarket amp power wire install step by step with pictures
Old 05-27-08, 09:49 PM
  #31
hihi410
hihi410's Avatar
Great write up and great post!
+1 for the OP
Old 06-08-08, 08:02 AM
  #32
VTLexus
VTLexus's Avatar
Originally Posted by WhatYaGot
I have the non-ml system. I used this post's information:
T-tap wires on the front woofer speaker wires. The right front door woofer wires are Brown (+) and Pink (-). The left front door woofer wires are White (+) and Red (-). Or you could just tap the factory sub wires to the new amp. The sub factory wires are sort of confusing on the schematics I have. The wires are either Pink (+) and Sky Blue (-) or Brown (+) and Light Green(-). Just pick the colors that are at the speaker for your install.
I am waiting to have someone tell us for sure which is the remote turn on for the non-ml system. I have heard different colors, but need someone here to let us know for sure. Right now my amp stays on while the car is on. Need to change this ASAP.
did you ever hear what the remote turn on wire color is?
Old 06-08-08, 08:23 AM
  #33
Batmobile
Batmobile's Avatar
here you go
Originally Posted by tt061880
edit: someone also asked about the remote wire, it's the ORANGE wire farthest to the back of the car. The other two bigger orange wires can also power up your amp but it would have the amp on 24/7.
Old 06-12-08, 05:06 PM
  #34
VTLexus
VTLexus's Avatar
subwoofer wires to tap from, BROWN and LIME GREEN, the NON ML version has two pairs, BROWN & LIME GREEN and PINK & SKY BLUE
i plan on doing my install this weekend....why would the stock sub woofer have two sets of wires? it is a one channel speaker...and does it matter which ones u tap?
Old 06-15-08, 05:17 PM
  #35
tt061880
tt061880's Avatar
Hi everyone, I've just updated the negative/positve leads for the front left/right and sub wires. Thanks to Batmobile for PM'ed me or else I would never realized that I left out such important informations, I apologize for forgetting to put that infos in there.
In regarding the wiring for the stock sub, it has two set of wires since it's a dual voice coil. I have the ML sub but if I was to do it on the stock sub, i'll input each set of wire into the LOC and then sum the output at the end. Please let me know if I'm missing anything for this DIY, i'll update it so it can be easier to follow in the future, thanks.
Old 02-15-09, 10:01 PM
  #36
lexboi250
lexboi250's Avatar
bringing this thread back alive!
This will probably solve my current problem right now, which is having to much low end bass, and almost no mids. When my woofer is playing the mids, it's hardly even moving, and just like tt061880 said, the lows are giving me too much headache, because my current sub is tapped to the rear speakers.
I'm gonna get a shop to rewire everything, tap them to the front speakers, and post the results. Thanks tt and technique!
Old 02-28-09, 10:30 AM
  #37
sexylexy28
sexylexy28's Avatar
Exclamation who all done this
i want 2 do this but i want 2 get experienced answer from people i dont want 2 spend the money for a clean sweep think its not worth it but if this works i need 2 know steps about pluggin into and wiring thanks
Old 03-10-09, 08:33 PM
  #38
tqlla3k
tqlla3k's Avatar
Sorry to bring this thread up again.... What exactly is meant by "Sum up the Bass signals"
I have a Factory Mark Levinson System
In two weeks I plan on installing my
1) Scosch FAI3A
2) Kicker TC10 Subwoofer in a box
3) Infinity Kappa 102A amplifier(Its overkill for the sub, I know)
I dont understand what I do with the Factory front woofer outputs... after I tap them via the Scosch LOC.
This weekend I am installing an Alpine MRP-M350 and an Alpine MRP-F240 into my 3000GT and then taking the Kappa 102a out of it. I am good with installing full stereo's... but am lost when it comes to intergrating aftermarket to factory units.
Old 03-15-09, 05:13 PM
  #39
tqlla3k
tqlla3k's Avatar
Hey, did you guys tap or remove the stock sub connection?
Old 06-20-09, 04:48 AM
  #40
BiTeZ
BiTeZ's Avatar
Can anyone please provide photos of where they grounded their amp assuming that you aren't getting any ground noise of course.
Old 07-07-09, 06:30 AM
  #41
BiTeZ
BiTeZ's Avatar
anyone have advice on where to put the amp ground wire to ensure no ground loop noise?
Old 07-07-09, 08:58 PM
  #42
vvsabvv
vvsabvv's Avatar
hi i have a 2007 is250 non ML i was wondering which plug is for the factory subwoofer and also which plug is for front door woofer? also i see that u have to hook up 4 wires to the LOC for the factory subwoofer.
now do you hook up both postive wires and both neg. wires to there own wire to the LOD or do you combine both postive wire to one wire and combine both neg. wires to one wire??
Old 07-09-09, 08:31 PM
  #43
vvsabvv
vvsabvv's Avatar
does anybody know where you can get the wirer diagram for the non ML stock amp??
Old 08-03-09, 06:23 PM
  #44
yukikaze
yukikaze's Avatar
Does anyone know if Scosche changed the model number for their 4 channel output converter from the FAI-3A to SLC-4? Are these two items still the same thing?
I'm ready to buy, but I don't want to buy a different converter.
Thanks
Old 08-03-09, 07:42 PM
  #45
OH Nasty
OH Nasty's Avatar
Amazing write-up. Thanks so much for doing it. Will be doing this next week.
Quick Reply: DIY aftermarket amp power wire install step by step with pictures
