Fog light problem
Fog light problem
How to change the fog light?? I cant see any place that can reach to the fog light...
I want to change a HID fog light...can some one post some pics how to install that?
Funny you should ask. I just came in from changing out the passenger bulb. There's a couple of good threads:
https://www.clublexus.com/forums/sho...d.php?t=186520
https://www.clublexus.com/forums/sho...d.php?t=197779
I recommend going through the wheel well. There are two plastic clips. Rotate 90 degrees and pull out. 7mm bolt (I think) on the bottom to unscrew. then just pull the wheel well plastic away from the fender. You'll have to pull pretty hard, but it will bend. Oh, and either wash the car, or at least clean the wheel wells, otherwise you'll be covered in brake dust.
Don't know anything about HID fogs, but there's at least one person on the forum who has had it done.
I need to add a HID headlight too...that need drill holes...
so...I planning to let the dealer to do it
