Still waiting for a proper dyno of the is350
Old 12-31-05, 11:40 PM
torqueaholic
torqueaholic's Avatar
Default Still waiting for a proper dyno of the is350
dyno jet dyno, with an sae correction, 4th gear pull.
get cranking guys. I'm guessing stock numbers should be about 255rwhp/245rwtq. the only other dyno thus far was a dyna pack dyno, and untop of that, it was a manufacturer dyno as well so you can basically disregard the data.
Old 01-01-06, 10:44 AM
stangd1909
stangd1909's Avatar
When I get mine I will be doing it really soon.....
Old 01-01-06, 04:07 PM
GILLEXUS
GILLEXUS's Avatar
FYI
Here is the drivetrain ratio for the IS
As you can see the 1:1 ratio for the IS250 RWD is 5th gear and 4th for the rest. 1:1 ratio is suppose to be the ideal for doing a dyno test. Some times it is hard to it in that low of a gear because when you hit the gas hard it wants to down shift.
This might be the case on the IS250 RWD.
Attached Thumbnails Still waiting for a proper dyno of the is350-is_specs_2222.jpg
Old 01-01-06, 04:43 PM
TheRupp
TheRupp's Avatar
I think the IS350 is rated under the current SAE standards, but I'm not entirely sure.
Old 01-01-06, 07:48 PM
GILLEXUS
GILLEXUS's Avatar
Yup your correct. the spec sheet states that
https://www.clublexus.com/forums/sho...d.php?t=175591
Old 01-01-06, 08:27 PM
2006is350
2006is350's Avatar
Hey, did you sell your cobra or trade? I traded my 03 cobra in on my IS 350, took alot of flak about it but it was a good decision.
T4styPh0
12-24-19 02:47 PM
finny76
GS F (2016-present)
15
07-21-19 01:14 PM
FSportIS
03-19-15 07:45 PM
ISMY350
Performance
29
02-03-14 12:39 PM
IS 350
04-01-08 12:42 AM
Quick Reply: Still waiting for a proper dyno of the is350
