View Poll Results: Does Homelink work with your rolling code garage opener?
Yes - Works like a charm!
71
80.68%
No - Can't get the darn thing working!
17
19.32%
Voters: 88. You may not vote on this poll
Old 12-15-14, 12:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Working Homelink with rolling code?
Old 02-05-08, 11:46 AM
  #31
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Originally Posted by PhilipMSPT
MY PROBLEM:
My condo's garage door has a rolling code, and I have NO access to the "learn" button on the garage door.
Any advice on this situation?
Do you mean main entrance ??
or
Like a 1-2 car garage for you car??
Either way, both have to have an accessible learn button..
Old 02-05-08, 06:11 PM
  #32
ExTrEmE99
ExTrEmE99's Avatar
I finally got the rolling codes to work on the IS.
Pressed learn button
go inside car and press the homelink button once and let go,
press it again and let go, press it again and let go.
worked, the garage closed and the light on the garage door blinked.
This thread should be added to the Faqs
Old 02-06-08, 08:03 AM
  #33
Joe Z
Joe Z's Avatar
^ Congrats!!
But 1st, you programmed your clicker to the homelink button in your car...
right...
Old 02-06-08, 10:34 AM
  #34
ExTrEmE99
ExTrEmE99's Avatar
Originally Posted by Joe Z
^ Congrats!!
right...
Nope, didnt even have the clicker in the car or around the car. Just used the learn button and pressed the homelink button inside the car 3 seperate times...
aEO 37 (10-15-20)
Old 02-06-08, 04:00 PM
  #35
Drunkebuda
Drunkebuda's Avatar
^^ might of had the code stored from last time because that cant work there needs to be a code from the remote if u press the two outer button for like 20 sec i think it will erase any codes in the buttons.
Old 02-06-08, 04:01 PM
  #36
Drunkebuda
Drunkebuda's Avatar
MY PROBLEM:
Humm there got to be a learn button somewhere...It usually is where the motor is or the control board. check the model number and brand online they will tell you where its at :P
Old 02-07-08, 01:01 AM
  #37
tfz_hebe89
tfz_hebe89's Avatar
Cool
Can anyone explain how to program the homelink system? I live in an apt where it uses a remote to open the main door, it opens by rolling to the side. Is it called rolling door type or just the normal garage door?
I tried the normal garage door for many times, but nothing. Dunno whether I did it right. Also if it really is the rolling door type, how can I find the whatever code?
Old 02-07-08, 04:28 AM
  #38
tex2670
tex2670's Avatar
Try reading this:
Old 02-07-08, 08:51 AM
  #39
Joe Z
Joe Z's Avatar
If its not your actual garage door / gate (like a main gate to a complex), you will most likely not have access to the learn button on the control unit.
Joe Z
Old 02-07-08, 10:39 AM
  #40
Shoyuu
Shoyuu's Avatar
MY PROBLEM:
Maybe someone from your HOA has access to it and they can hit the learn button for you?
Old 02-25-08, 10:42 AM
  #41
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
Most HOA don't want or allow this. They'd rather sell you a remote they can track for $35. At least mine in CA would not do this. My new community has a smart chip for gate access. No codes no buttons.
Joe is dead right about clearing the old codes. I tried and tried with a Genie in my rental and it would not work until I cleared the entire Homelink, programmed with the remote, then hit the learn button and voila!
Old 04-16-08, 08:10 PM
  #42
Eternity3G
Eternity3G's Avatar
My parents have a rolling code and and I almost threw a fit not getting it to work. I did this on my GS and helped a friend do it at his new place in his IS. The key is to 1st follow the instructions on programming the with the remote control, THEN going following the instructions on the "Rolling Code" section. Don't proceed directly to the "Rolling Code" section in the manual.
Program with Remote:
1) Point the remote control for the
device 1 to 3 in. (25 to 75 mm)
from the HomeLink�� control buttons.
2) Press and hold down one of the
buttons on the HomeLink�� and
the button on the transmitter.
When the indicator light on the
HomeLink�� changes from a slow
to a rapid flash after 20 seconds,
you can release both buttons.
3) Test the operation of the
HomeLink�� by pressing the newly
programmed button.
3-b) If programming a garage door
opener, check to see if the garage
door opens and closes. If the
garage door does not operate, see
if your garage transmitter is of the
Rolling Code type. Press and hold
the programmed HomeLink�� button.
The garage door has the rolling
code feature if the indicator
light (on the HomeLink��) flashes
rapidly for 2 seconds and then
remains lit.
Program Rolling Code (After performing above instructions!!!) VERY important!
1) Locate the training button on the ceiling mounted garage door
opener motor. The exact location and color of the button may
vary by brand of garage door opener
2) Press the training button.
3) Press and release the vehicle’s programmed HomeLink�� button
twice. The garage door may open.
If the garage door opens, the programming process is complete. If the
door does not open, press and release the button a third time. This third
press and release will complete the programming process by opening
the garage door. (I had to press 4 times)
The ceiling mounted garage door opener motor should now recognize
the HomeLink�� transceiver and operate the garage door.
Hope this helps!
Old 04-16-08, 10:39 PM
  #43
tfz_hebe89
tfz_hebe89's Avatar
Joe Z
It is a main gate to the complex. hmm, so i could not set up the homelink since I have no access to the learn button?
Old 04-17-08, 09:35 AM
  #44
shn7926
shn7926's Avatar
programmed button.
remains lit.
Hope this helps!
just an fyi. i did this exact procedure like 10 times after having the rear view mirror tsb done, and it would not work on door number two, but door number one worked fine. i even programmed all three buttons for door number one and they all worked, so i knew it had to be something with the opener itself, not the homelink. after trying everything i could imagine, i finally tried using another clicker for the first part of the procedure and it worked. something was wrong with the signal in my clicker, even though the clicker would open the door, it would not program with the homelink. no problems since...
Old 08-05-08, 03:17 PM
  #45
w1ck3d64
w1ck3d64's Avatar
omg this helped me so much...after a year of not using homelink LOL
Quick Reply: Working Homelink with rolling code?
