View Poll Results: Does Homelink work with your rolling code garage opener?
Yes - Works like a charm!
71
80.68%
No - Can't get the darn thing working!
17
19.32%
Voters: 88. You may not vote on this poll
Old 12-15-14, 12:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Working Homelink with rolling code?
Old 02-01-08, 12:15 PM
passnu2
passnu2's Avatar
It will work. just follow the instructions as many have said above. we need to make a sticky with some step by step pics with instructions.
Old 02-02-08, 06:32 AM
4TehNguyen
4TehNguyen's Avatar
have to use the learn button on the garage opener, I followed the instructions and got it the first try
Old 02-02-08, 06:38 PM
Rare1
Rare1's Avatar
I have a Genie Intellicode garage opener. I haven't been able to get Homelink to work. I tried on both the GS400 and my wife's IS300 and it just doesn't want to work. Anybody got any suggestions I would greatly appreciated it. I know this is a 2nd gen IS thread but hey I need help.
Old 02-02-08, 09:29 PM
CrazyMPG
Phat Monkey
CrazyMPG's Avatar
yea...i have a genie one too...and i can't get it to work on the 2IS...
I keep on going back to the garage motor to push the learning button then rush back the IS to program it...but it won't work!
The RX, GS, Toyota Prius was easy...but can't get it to work for the IS...
Old 02-02-08, 11:49 PM
XprincoX
XprincoX's Avatar
i got it working with my genie opener... i had to basically cloned one of my existing remotes.
Old 02-03-08, 05:03 AM
tex2670
tex2670's Avatar
Try getting new batteries in the remote first. I have a Genie, and that's what solved my problems
Old 02-03-08, 12:26 PM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
You only need NEW Batteries if your Clicker is NOT working at all....
Follow Below:
Originally Posted by Joe Z
I have a rolling code entry gate and garage..
Both work perfectly with the Homelink..
- when you slowly folllow the step-by-step instructions in the owners manual.
In a nut shell, first you program the clicker to your home link button by pressing & holding both buttons till the little light flashes (follow directions in manual), then you hit the learn button on the above garage opener unit and then press and hold the homelink button in the car that you just programmed to the clicker... you know it works as soon as the garage light bulb flashes.
Takes under a NY minute...
Jz
Old 02-04-08, 09:19 AM
Rare1
Rare1's Avatar
It's funny you mentioned the battery, one of them died last week and it looks like it might be the original. I'll try it after i replace it.
Thanks for the suggestion.
Old 02-04-08, 10:12 AM
tex2670
tex2670's Avatar
Follow Below:
That was not my experience. My clickers all worked, and the HomeLink blinked to indicate that it "learned" the remote, but the whole process, which I tried countless times, did not work until I put a fresh battery in the Genie remote--then it worked on the first try.
Old 02-04-08, 10:57 AM
Joe Z
Joe Z's Avatar
Thats really weird.....
Old 02-04-08, 11:58 AM
tex2670
tex2670's Avatar
It must be a common problem, because it says right in the owner's manual that you should replace the battery before you start the process.
Old 02-04-08, 12:08 PM
Joe Z
Joe Z's Avatar
Hmm - I guess soo...
I've owned two Lexus' in 5 years and never had to put new batteries in the clicker, when programming the Homelink..
I wonder why its on the last page....
Btw - Nice PDF!!!
Old 02-04-08, 04:06 PM
Drunkebuda
Drunkebuda's Avatar
Park it in the garage some instructions dont work like camberlin garage door. You have 30 second to program it. I remember i had to press the button like twice before it stored the code. Follow joe Z instructions that should make it work.
Old 02-04-08, 10:06 PM
PhilipMSPT
Cycle Savant
PhilipMSPT's Avatar
MY PROBLEM:
My condo's garage door has a rolling code, and I have NO access to the "learn" button on the garage door.
Any advice on this situation?
Old 02-04-08, 10:46 PM
CrazyMPG
Phat Monkey
CrazyMPG's Avatar
got it to work! basically I just cleared out the home link then followed the directions on this post! thanks a lot people!
Quick Reply: Working Homelink with rolling code?
