Need advice on a turbo.
CAR--- 2002 is300
5 SPEED
ENGINE---6 2JZGE VVTI 3.0 LITERS---(stock engine)
TURBOEAST MANIFOLD.
TURBONETICS MARK II WASTEGATE
GREDDY TYPE S BLOWOFF VALVE
3 INCH DOWN PIPE
EPI TUNNING FUEL PUMP
Dezod Motorsports Custom AEM EMS Stand Alone Engine Management Systems
Want to make 300-600 HP (daily driver)
Planning on changing the headgasket to the 2jzgte and water pump
I choose to go with Turbonetics and was advise by turbonetics to go with the following part 11011.---
PART# 11011.---
{The T04B and T04E series are the most versatile turbochargers available to the performance aftermarket. High compressor efficiency, strict quality standards, TURBONETICSŐ exclusive “blueprinted” assembly process and competitive pricing makes the T04B and T04E the obvious choice for many applications.
Available in a wide range of compressor and turbine combinations, the T04B and T04E family can support power levels from 300HP to 550HP for single turbo applications and over 1000HP for twin turbo applications on engines from 100CID to 500CID.
T04B AND T04E TURBOCHARGER OPTIONS
All T04B and T04E turbochargers are available with dynamic or carbon sealing and dry or wet bearing housings
Standard configuration includes on-center or tangential turbine housing
T04B/T04E turbochargers are also available with TURBONETICS exclusive patented Ceramic Ball-Bearing option**
PLEASE ADVISE IF THIS IS A GOOD SUGGESTION OR IF SHOULD GO WITH A DIFFERENT TURBO FROM TURBONETICS.
5 SPEED
TURBOEAST MANIFOLD.
3 INCH DOWN PIPE
PART# 11011.---
