IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
New is owner
Old 12-06-13, 02:52 PM
Downtbrown
Downtbrown's Avatar
Default New is owner
Hey everyone just wanted to say hi and stuff. I'm new to this whole forum thing haha. We'll I have a 02 is Lexus not sure wat to do with it yet! But anyways anyone have ideas about deep we'll rims?
Old 12-09-13, 11:33 PM
xxDJBxx
xxDJBxx's Avatar
Start with BC BR Coilovers.
There should be a 2JZGE Turbo build post around here.
Old 12-10-13, 07:53 PM
volkce28n
volkce28n's Avatar
I recommend Koni Yellow struts with Eibach Pro Kit springs if this is your daily driver, rides a bit stiffer than factory, but handles like a dream.
Old 12-11-13, 06:07 AM
is3wagon
is3wagon's Avatar
I agree with the koni struts and eibach springs. I just got a great price fridiay for that exact set up. PM THMotor and he will hook u up. I did! Good luck and welcome.
Old 12-11-13, 09:38 AM
volkce28n
volkce28n's Avatar
those are the same guys that hooked me up, great prices!
Old 12-11-13, 04:27 PM
khay425
khay425's Avatar
welcome
Old 12-19-13, 07:34 PM
Jaybeck860
Jaybeck860's Avatar
welcome man!
Old 12-20-13, 08:51 AM
dylyxcore
dylyxcore's Avatar
suspension first
Old 12-20-13, 02:30 PM
Jstinson12
Jstinson12's Avatar
Same here man 2001 is300. Starting with navigation and suspension! WELCOME!
Old 01-10-14, 03:48 PM
Downtbrown
Downtbrown's Avatar
Thanks guys I did bc coilovers and now thinking about turbo!
Old 01-13-14, 04:35 PM
xxDJBxx
xxDJBxx's Avatar
Good! Now, you said you wanted to go Turbo. Making a 2jzge Turbo is pretty straight forward. Depending on the amount of HP you want, you'll have to upgrade Clutch / Transmission / Driveline / Rear Diff so that everything can handle the power, and that you get the best power to the wheels as possible.
First Determine:
What is my HP Goal?
You started with Suspension First, so I will assume you're wanting at least 400HP, but no greater than 550HP..
You could get everything you need for about $4000 - $4700.
Things you shouldn't cheap out on:
Exhaust Manifold, Ebay manifolds SUCK, I have a contact that Fabs them.
Turbo, Borg-Warner S300 ($750) (I know a guy)
Clutch, Go 6-puck Double Disc.
Injectors, 1200cc.
My friend is in the middle of his build, which is likely the same as yours, but he wants a little more HP, what he has is perfect for what you're trying to do, if I'm correct.
Good Luck, Post here if you have any questions.
dniice
HS 250h Model (2010-2012)
10-15-19 05:38 AM
Cptrob
Suspension and Brakes
03-09-18 09:27 AM
seifm
01-15-13 07:25 PM
jayreyes
01-03-13 03:27 PM
3rdelement
12-07-12 03:25 PM
Quick Reply: New is owner
