IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
sticking calipers upfront
Old 02-19-11, 07:56 AM
Avarec
Avarec's Avatar
Default sticking calipers upfront
my front pass caliper is sticking and id love 2 replace it, should i go for a used one or aftermarket ne, or even refurbished one
how hard are these to replace
anyone else had this problem
Old 02-19-11, 02:39 PM
rvalero
rvalero's Avatar
One of the pistons on my driver's side front caliper was sticking. Lexus replaced it under extended warranty. Unless you track your car, I recommend OEM.
Old 02-19-11, 04:07 PM
llllllllll
llllllllll's Avatar
Aftermarket = expensive
Swapping calipers from other cars (supra or LS) = costly + custom work + time
your best bet is get OEM from local junkyard
option 2 - get a used one from classifieds section if you dont mind paying shipping on a heavy 30Lb piece of metal
option 3 - bring your current one to lexus to be rebuilt... $$$
option 4 - aftermarket or caliper swap
Old 02-19-11, 04:55 PM
Avarec
Avarec's Avatar
i went to salvo auto parts and ordered a 1 cardone rebuilt one, w core swap
well my car does have 160k so no warranty and no i dont track it so oem spec would be just perfect
also will i have to bleed the brakes?
Old 02-19-11, 05:02 PM
rvalero
rvalero's Avatar
No problem, and yes, you will need to bleed the brakes.
Old 02-19-11, 05:34 PM
Avarec
Avarec's Avatar
youre great my freind, thanks so much
Old 10-12-13, 04:23 AM
nxrunner
nxrunner's Avatar
I believe my pass front caliperis sticking as well
. Changed the pads but don't recall using any grease on the pins ... so could this be the problem or more likely its the caliper itself (piston verses bolts/slide pins)
Old 10-12-13, 04:41 AM
MasterKwan
MasterKwan's Avatar
I'd just take it back apart and look at the slidey pins. I worked on a GS the other day, same brakes as the IS and the lower slidey pin took a slip hammer to get loose. Water got in behind the boot and it rusted up.
Old 10-12-13, 05:35 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Three options for stick brakes:
1: slide pins not sliding: (usually shows as severe uneven pad wear inside vs outside pad) solution - remove, clean and lubricate; remove replace and lubricate; or if it is frozen badly, replace the caliper mounting bracket
2: sticky caliper pistons: (cant compress pistons, even with bleeder open) solution - replace or rebuild
3: bad brake line (allows fluid to compress brakes but not release, diagnose by trying to compress caliper pistons and if they won't compress at all to start but if you open bleeder, they do compress, brake line is bad): solution - replace brake line
gabzor
09-29-13 09:41 PM
Lukas99GS
Suspension and Brakes
08-27-13 10:00 AM
TooCool4u
13
02-27-13 02:28 PM
j stuff
10-31-07 07:31 AM
Quick Reply: sticking calipers upfront
