IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
day light bulbs
Old 01-26-10, 10:25 AM
azngai8624
azngai8624's Avatar
Default day light bulbs
how do i change the day light headlights to look the same as the night light? do i need any special hid kits or just need to buy new bulbs?
Old 01-26-10, 10:41 AM
lexdymndz
lexdymndz's Avatar
Not sure what you are trying to do. I think you want the daytime running lights to be brighter, if I am not mistaken. If that is the case, it is an easy fix. You need to do the DRL override mod. Here is the DRL Delete mod: http://my.is/forums/f90/how-disable-...lights-246780/
All you need to do is run a jumper wire from on socket in the plug to the other. Now when I say plug, I am referring to the part that plugs into the DRL module, not the DEL module (box, pointed out in the link).
Hope the helps.
Old 01-26-10, 01:26 PM
azngai8624
azngai8624's Avatar
oh yea i just need to make the (drl) the same as the (nrl). sry for the bad question
Old 01-26-10, 09:08 PM
rvalero
rvalero's Avatar
You can change the bulb, and do the full power DRL mod. It will look closer to the low beams, but it won't look the same. According to this thread (http://my.is/forums/f90/quick-hids-drl-question-380203/), the full power DRL mod will not work with HID's - See post #7 in the linked thread.
EDIT: as rapev-8 mentioned, you can run LED's. Here's a link that should help you out.
http://my.is/forums/f90/free-solutio...roblem-394823/
Old 01-26-10, 10:25 PM
rapev-8
rapev-8's Avatar
how bout using LED headlight bulbs? they use less power right?
Old 01-26-10, 11:39 PM
azngai8624
azngai8624's Avatar
thanks for all the replys now il go try it out
BrandonIS
12-22-12 06:44 PM
Kumar350
08-22-12 09:33 AM
dahozy
04-17-09 10:30 PM
I8ABMR
05-27-08 08:38 AM
PNice972
05-31-06 06:23 PM
Quick Reply: day light bulbs
