Hybrid Code C1378
Hybrid Code C1378
What's up guys? Just had my car scanned after the light below came on. I was told that it's code C1378 Capacitor Communication Malfunction. Has any of you experienced this before. Your help is greatly appreciated.
Thanks!
Thanks!
You must of hit the "disp" button on your steering wheel. Considering that the past 3 (and only) posts you made are showing the same issue let me explain the icons you see.
All this is is showing you is where the drive is coming from. Whether the car is driven battery alone, motor alone, or both together. You have driven 138836 miles as ODO stands for odometer.
This is essentially the same information you would see with the "energy" display of the "info"-> "fuel consumption"-> "energy"
Regarding the error. I don't see any indication of an error. Perhaps the light is in the right dash pod that is not pictured.
Note: If you want to feel real gs450h acceleration switch Pwr mode to Hybrid. It's a small switch under your center console arm rest. You should turn your parking sensors on too (left hidden dash panel). Sport suspension is a hoot too! (next to the pwr mode button)
whytry
02-10-18 05:16 AM
