HS 250h Model (2010-2012)
Loud rattle behind glove box
Old 11-27-15, 05:17 PM
Dechristie
Dechristie's Avatar
Default Loud rattle behind glove box
Hello,
I have a 2010 hs250h. When I turn on the ac/heater, there is a loud rattle from behind the glove box. I checked the fan motor and it seems ok. Any suggestions? I also checked the recirculating function and it is ok.
Many thanks,
David
Old 11-28-15, 11:11 PM
toomeypj
toomeypj's Avatar
Did you check the area where the cabin filter slides in? Maybe something came loose or a rodent got in there tried to make a nest. The debris could be hitting the fan when it rotates.
Old 11-30-15, 12:54 PM
Clutchless
Clutchless's Avatar
Received 1,098 Likes on 937 Posts
Open up the cabin air filter area and try to vacuum it out. Access instructions are in the manual or Youtube, just use the search term Lexus, not HS250h, as they are all the same. I agree it may be leaves in the fan motor. I have seen this on other cars. or maybe the filter cover got loose. Some of the similar threads listed below may provide help.
Old 12-01-15, 03:19 PM
homoonar
homoonar's Avatar
Happened to me before. It was a leaf inside...
JackRyan16
11-07-17 05:40 PM
Lveyolfe
05-26-17 02:38 PM
Stun350
Suspension and Brakes
06-09-16 04:57 AM
edarias
03-08-12 11:24 AM
MASSMINI
RX - 1st Gen (1999-2003)
04-02-10 08:27 PM
Quick Reply: Loud rattle behind glove box
