Enform Weather-Traffic Issues
Old 01-04-15, 04:47 PM
Norman53
10th Gear
Norman53's Avatar
Default Enform Weather-Traffic Issues
Has anyone had issues with Weather/Traffic displaying no data or a Enform agreement is needed to access. I normally can get the weather forecast including the 3 day forecast and in the past I was able to view the weather map. For the past couple of weeks the forecast displays but map displays "no data". My smartphone is connected to the car and the data setting is set for HD/cell.
Thanks
Norman53 is offline
Old 01-06-15, 01:49 PM
offroad200
offroad200's Avatar
Thanks
Have you downloaded the Lexus Enform App Suite app? This is the backup for weather/traffic data in the event of a weak or nonexistent HD radio signal. If not, download that and go to the App suite in your car and make sure it's updated as well. I say that because if the App suite in the car has never been used, it will need to do an update. Otherwise, try disconnecting the battery for a few minutes. This will force the HD tuner to look for a signal.
offroad200 is offline
Old 01-06-15, 02:44 PM
dmccombs
dmccombs's Avatar
Norman,
Getting weather through HD started in the 2014 models I believe. If you are using the Enform app, it has to be running on your phone, and be awake.
On my iphone (since ios 8), the app will be running, but will go into some sort of sleep mode. I need to fish out my phone and select the Enform app. Once I tap the Enform app icon, it wakes up and syncs with the car. then everything works. Maybe you are having a similar problem.
dmccombs is offline
SirKong
RX - 4th Gen (2016-2022)
20
01-14-20 12:44 PM
Bearcat
06-07-17 06:36 AM
Slust
05-07-15 06:10 AM
CobraGSF
04-22-14 12:38 PM
Quick Reply: Enform Weather-Traffic Issues
