GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
DIY Front Wheel Bearings
Old 11-11-12, 05:00 PM
wolfalp159
wolfalp159's Avatar
Default DIY Front Wheel Bearings
This is for a 2006 GX. Not sure how others differ. When faced with an expensive wheel bearing replacement I decided to do it myself. I found little help online and ended up purchasing the alldata online workshop manual wich was moderately helpful.
First I purchased the parts from Sewell Lexus using the club discount. Thanks guys.
1- Remove brake pads as if replacing pads
Remove brake line holder bolt
Remove Brake Disk bolts
Hang brake caliper from strut
Remove metal cover to access axel nut
Old 11-11-12, 05:06 PM
wolfalp159
wolfalp159's Avatar
Default Part 2
Remove cotter pin and axel nut cover
Remove axel nut
soak 4 bolts with blaster to make removal easier
This was the hardest part. I had to make a puller attachement as the one from O'Reily was to narrow or would not fit over the lip.
Soak for some time with Blaster then pull on hammer. Diver side came out easy. Passenger side took 45 minutes of slide hammering
Old 11-11-12, 05:15 PM
wolfalp159
wolfalp159's Avatar
Default Part 3
Removed
New parts from sewell
Attached wheel bearing and dust cover. This took a little effort. I used a piece of copper pipe and hammer to hammer onto wheel bearing
Back from machine shop, $5 later
Bolted back into place
The axel nut torque is 175lbs, this was more difficult than other wheel bearings I have done but not too difficult. After hearing prices of over $1,000 at the local dealer this was a good job. Less than $300 with machine shop included.
Old 11-12-12, 11:23 AM
ROSCOGX470
ROSCOGX470's Avatar
Could you describe the issue you were having that led you to replace both wheel bearings?
Old 11-15-12, 05:39 AM
Ancient
Ancient's Avatar
Excellent write up, plan to repack my wheel bearings this winter.
Old 11-15-12, 06:55 PM
wolfalp159
wolfalp159's Avatar
The wheel bearings showed signes of wear in two ways. I have 75,000 miles on the car. The driver side wheel started making a roaring noise on rotation. It would subside when the stearing wheel was turned to the right. When I took off the tire and pushed on the hub I could notice the movement was signifiacntly more than the passanger side. There should be no play in the hub.
Old 11-19-12, 05:22 PM
AVnGX
AVnGX's Avatar
Great write up.
I undertook the same job, but had a lot more headaches than you.
There was no way the sledge slider puller was going to budge the hub from the bearing. I had a shop press them apart.
I still have not reassembled them yet as I am waiting for parts.
I also found a bad knuckle to axle seal on the driver side.
You mention the axle nut torque is 175 ft/lbs? That seems high? Where did you get this?
I just want to make sure I use the right value.
Also, how did the old hub fit into the new bearing? I assume since it was hard to separate, its going to be similar to re asseble with a new bearing? Did you assemble them on the bench first? With a big hammer?
Thanks for your advise... I need help
Old 12-02-12, 03:58 PM
wolfalp159
wolfalp159's Avatar
You are correct, what I pulled was axel and hub, then machine shop pulled them apart and pressed the new one together.
the 175 ft/lbs came from the ALLDATA web site. Had to pay for that.
I had the machine shop press them back together after I replaced the rubber grease seal.
TurboTodd
10-26-23 04:19 PM
WIL44
07-06-21 03:00 PM
grandamliz
Suspension and Brakes
109
06-18-17 11:00 AM
TriniLex
01-28-17 05:29 AM
koksik
Wheels, Tires & Brakes Forum
13
10-07-10 03:20 PM
Quick Reply: DIY Front Wheel Bearings
