GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
DIY, Bank 2 Sen 1 O2 sensor replaced
Old 05-22-12, 03:39 PM
BurgBoxstr
BurgBoxstr's Avatar
Twins! Mine too is an '04 who just turned 127k and my B1S1 O2 went back in Sept.
Mileage at the time was ~ 111k - used the Bosch b/c Denso would've taken 2-3 days to get in via parts store.
O2s are usually good for 100k so I got +11% on one and the others I'm +27% and rolling
Good luck
Old 05-22-12, 03:57 PM
TopGear300
TopGear300's Avatar
That is funny, and really exactly when mine went out.
I don't suppose you still have the link of the new sensor you bought?
And on a separate note: has any one here had a GX with a speedo problem? I am in desperate need of some advice here I'm just seeing high bills and my inspection is due in June and I don't have the money to fix it HELP
https://www.clublexus.com/forums/gx-...eedo-help.html
You guys are da best
Old 05-23-12, 12:27 PM
BurgBoxstr
BurgBoxstr's Avatar
Sorry, I do not. It was a Bosch O2 at AdvanceAuto... they recommended b/c the Denso was only available for order and 3-4 days out. Think it might have been ~ $100 but I used one of their readily available 20% off coupons. As mentioned previously, stick w/ only Denso or Bosch.
Old 06-03-12, 08:12 PM
TopGear300
TopGear300's Avatar
After you have installed the new sensor....do the lights go off and the code is erased and re-set or do you still have to do that manually?
Old 06-09-12, 04:29 PM
rbx10
rbx10's Avatar
Thank you very much for the post. I may use it some day.
Old 12-01-16, 05:40 AM
rahiman9
rahiman9's Avatar
dear all,
I am using lexus Rx 350 and having problem with bank 2 sensor 1 after diagnosis the system. please help to find the location
Old 12-01-16, 06:26 AM
chiph9
chiph9's Avatar
Sorry, this forum is for the GX. Try posting in the RX forum for the generation of your SUV.
Chip H.
rahiman9 (12-13-16)
Old 12-13-16, 07:07 AM
rahiman9
rahiman9's Avatar
P0051- oxygen sensor bank 2 sensor 1 for RX 350Dear ALL,
i have problem with oxygen sensor bank 2 sensor 1 for lexus RX 350 model 2009.
Can i anyone help me to find the location for Bank 2 sensor 1 with picture if possible and also the spare part#. for the same.( code - p0051)
Appreciate your kind assistance.
Old 12-13-16, 06:37 PM
tz693
tz693's Avatar
This is GX470 forum. You need to post on RX350 forum to get answer.
Old 02-03-20, 08:30 AM
pmendonc
pmendonc's Avatar
Thank you for this write up. I followed these steps to fix my P0051 code. The special wrench is a must. I bought one from Auto Zone and returned it for a full refund.
My check engine light went off the following morning, one day after replacing the sensor.
Old 06-06-20, 06:43 PM
47BA
47BA's Avatar
Default P0051 on 2007 GX
What year is yours? I’m looking at my 07 and wondering if I can even get to it myself.
Old 06-07-20, 07:34 AM
agent15
agent15's Avatar
I'm in my garage right now trying to figure this out on my '06 with 110k to cure a P0031 code (driver side).
Unfortunately it appears the sensor on that side may have already been replaced. If that's the case, I fear I may be looking at exhaust manifold replacement because I can hear it leaking.
Old 06-07-20, 11:11 AM
agent15
agent15's Avatar
I got the driver side sensor replaced. Figuring out how to undo the clip took a ridiculously long time - as did figuring out how to get my hands actually in there to do it - but it I wanted to test the sensor first. This appears to have resolved the CEL after clearing and checking codes. 🤞
Now that I've had something to eat, and cooled off both figuratively and literally, it's on to the passenger side (preventive while I'm here).
As for the clip, I had success getting a finger on the back of the release on the harness, while wedging it against the block for leverage.
mrblister
07-25-17 05:49 PM
LEXZILLA
05-08-15 06:10 PM
racerxxv
12-29-13 08:23 PM
sullijd
Performance
13
11-02-11 08:40 AM
dealer374
Maintenance
11-15-10 05:54 PM
Quick Reply: DIY, Bank 2 Sen 1 O2 sensor replaced
