GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
60k Service List?????
Old 06-29-09, 08:33 AM
K-Bud
K-Bud's Avatar
Question 60k Service List?????
ANyone know what all is detailed in the 60k Maintenance Schedule for the GX470?
Want to see what is performed at the dealer and what I can do myself.
Thanks
Dan
Old 06-29-09, 11:01 AM
cssnms
cssnms's Avatar
What does your owner's manual say?
Old 06-29-09, 01:07 PM
K-Bud
K-Bud's Avatar
I have no idea what it says as the car didn't come with one since we bought it used. Was this your way of saying RTFM?
Old 06-29-09, 06:31 PM
cssnms
cssnms's Avatar
But since this is not the usual case of someone that is to lazy to look themselves and since you are a fellow Marylander let me summarize...
Replace engine oil and oil filter
Lubricate front drive shaft bushings
Measure brake pad thickness and rotor runout
Replace active height control system fluid
Replace brake fluid
Replace engine filter
Replace transmission fluid
Re-torque drive shaft flange bolts
Rotate tires
Inspect nuts and bolts on chasis
Lubricate propeller shaft retorque bolts
Repack front wheel bearings
Repalce air conditioner filter
Replace differential oil
Repalce tansfer case oil
Road-test
Various items that also require inspection
Ball joints and dust covers
Body
Brake lines and hoses
Charcoal canister
Differential oil
Drive belts
Drive shaft boots
Engine coolant
Engine valve clearance
Exhaust
Fuel lines and connections, fuel tank band, and fuel tank vapor vent system hoses
Fuel tank cap gasket
Rack and pinion assembly
Steering linkage and boots
Transfer case oil
Transmission fluid
Old 06-30-09, 06:36 PM
K-Bud
K-Bud's Avatar
THANKS! Now some of that I have performed and some is probably overkill or not needed but more or less preventative but my real question is without me calling Towson Lexus and asking what this would run minus a few things I've already done very recently what do most Dealers on average charge for a 60k Service Inspection?
anyone have any input on what they have been charged or seen from other members on the board?
thx alot
Dan
Old 07-01-09, 12:15 AM
mann777
mann777's Avatar
Talking
Bud they are all up available on lexus.com, where if you register with your vehicle details, you can download for free. All instruction including the owners manual, maintenance charts or service chart are available as freebees.
Old 07-01-09, 05:34 PM
K-Bud
K-Bud's Avatar
Thanks for the tip!
Old 07-06-09, 10:27 PM
pump142
pump142's Avatar
so thats why they want $800 for it
Old 07-07-09, 08:26 AM
tromly
tromly's Avatar
You can easily purchase an owners manual on Ebay, should run $15.00-$25.00 complete with the leather holder. If you want the Lexus first aid kit, they are also available for around $10.00. Good Luck
pam1980
RX - 3rd Gen (2010-2015)
15
11-21-18 12:26 PM
Zinda
04-15-14 07:21 AM
timucla
08-19-08 11:09 AM
ES3
08-06-08 08:16 AM
GGGXXX
01-29-08 07:12 AM
Quick Reply: 60k Service List?????
