Auto dimming driver-passenger mirror replacement
My 2005 GX doesn't have auto dimming driver-passenger side mirrors. I was told this became available from 2007 model onwards.
Is there a way for me to replace 2005 mirrors with either 2007 or 2008 mirrors?. When I asked Lexus dealer parts department, they said it can't be done as it involves rewiring.
If Lexus mirrors are out of option, is there any after market duto dimming mirrors available?. I hate driving in the nights with full bright truck lights reflected on my face..
I have a 2007 and that was not available at the time of purchase in 10/06. It would be intreseting if they offered it in later in the year. I drive at night alos, and hate the brigth lights b y truckers and car.
Dealer's right. It would require rewiring, as well as possibly some more parts.
When I had the RX300 (before my GX) I decided to put in the interior auto dimming mirror (mine did not come with it). I bought the mirror on ebay (standard Lexus RX300 auto dimming - not aftermarket, ... yes, I'm cheap). I figured that the main harness was in place, that the only thing I had to do was to plug it in. Well, .... no. I soon discovered that there was no main harness to plug it into. Since the car had no auto dimming option, the harness was not installed in the factory. OK, improvise. I started playing with the mirror in the test bench setup using 12V regulated power supply, trying to get it to respond to light input. The results were .... surprising. The mirror would not respond to light changes, and either would be in the clear, or fully dimmed setting depending on the wire combinations I tried. The good news was - the compass was working! Well, I didn't buy the auto-dimming mirror for it's compass function!, ... right, back to drawing board. By analyzing the car wiring diagram, I realized that the interior mirror is also responsible for dimming the two exterior mirrors, which my car did not have. Once I discovered that, I needed to substitute something for the two exterior mirrors. I used two coils from the 1.5inch colling fans (pc 12v - I know, I know, but that's all I had handy). That made the mirror function perfectly. Traced some wires under the headliner, located switched circuit, and ground, connected the mirror, hid the coils in the headliner, worked perfect - never looked back ... well in the mirror yes :-)
The point is, that even if you get the new auto-dimming exterior mirrors, they will need to be controlled from the interior mirror. If the stock stand-alone interior auto-dimming mirror does not have the wires to control the dimming of the exterior mirrors, you would also need to replace that mirror as well. At which point you would have to test if it would work only with one exterior (assumption you want to put in only driver side), or would you need to replace both exterior to auto-dimming.
Wow, that came out longer than intended. I hope I make sense. It would be nice to get someone from the dealer techs to comment.
Good luck.
Good luck.
For sure it is available in 2008 models. It is on Lexus.com. However, my local dealer said that it became available from 2007 onwards.
Is there any after market mirror available with auto dimming feature?. I wonder why not much response to this thread..... looks like many are happy the way it works without being dimmed !!!!
http://www.lexus.com/cpo/model_library/GX/2006.html
According to the Lexus.com website. This is available on the 2006 model year. Can anyone verify? I sold my Nissan Murano due to this, and a few other, reasons.
I definitely have the auto-dimming inside rear-view mirror and I'm loving it. Never paid close enough attention to notice if the outside mirrors have that as well. But if they don't, it does not bother me to the point that I would want to swap them.
What does bother me is that my 4Runner does NOT have heated mirrors!!!
Satiger, if you decide to go ahead and swap out the mirrors, let me know, I'll be interested in buying your stock ones.
