Exhaust Tip PICS?
Old 03-24-07, 10:56 AM
Pearlpower
Pearlpower's Avatar
Default Exhaust Tip PICS?
Looking to get some ideas on a nice exhaust tip replacment.
Still contemplating running dual exhaust or a larger oval shaped tip.
Anyone care to share their pics?
thanks
Old 03-25-07, 10:26 PM
GS3Tek
Forum Moderator
GS3Tek's Avatar
PP, I haven't seen any one here posted either dual or larger exhaust tips.
However, I did see a current gen 4runner with dual oem exhausts, one on each side. Looks more balanced...I've contemplated on doing it also.
Old 03-26-07, 12:55 AM
Pearlpower
Pearlpower's Avatar
Thanks, I agree, the dual setup would look balanced. I need to craw under tomorrow and see where I can route another pipe to the other side. The hitch is in the way out back so that area is out of the question.
thanks
Old 03-26-07, 03:13 PM
BobsGX
BobsGX's Avatar
thanks
I don't think its the trailer hitch that is in the way, well maybe the trailer wiring connector, but the components for the rear air suspension. I don't think the 4Runner has the same setup under there so that vehicle probably has the clearance needed for another tail pipe.
Old 03-26-07, 04:04 PM
Pearlpower
Pearlpower's Avatar
It's the that connects to the frame that is in the way preventing the pipe to crossover right in front of the spare tire. Plus the small tow hook is in the way of the exhaust tip for the left side which I just checked. I will gander at it some more when I have it jacked up to check for header clearance.
Old 03-27-07, 03:56 PM
Pearlpower
Pearlpower's Avatar
After checking some more, another pipe can easily run under the rear sway bar in between the spare tire and differential and then over to the left side to come out. I would have to install a heat shield for both the spare and differential but very doable. Perhaps next week when I find some nice tips and finalize which muffler is going to replace this monster overweight dinosaur under there now.
Old 03-27-07, 05:02 PM
GS3Tek
Forum Moderator
GS3Tek's Avatar
Nice. Keep us updated
Will there be any negative consequence for running the long pipings for the left exhaust?
I don't remember an introduction from you on your new GX
Old 03-27-07, 05:38 PM
Pearlpower
Pearlpower's Avatar
I do not see any negatives at this time. Doubtful of any power increase or decrease. One muffler shop recommended just installing a fake tip back there as often does happen but I am the type of guy that would rather get it done right.
At this time I am looking at quad tips (two of each side) or just a dual tip setup.
I am normally in the SC430 forum but decided to mod the GX a little to give it a more sporting nature.
Old 04-06-07, 05:41 PM
Rx900
Rx900's Avatar
Here's a 4Runner with Dual exhaust.
Old 04-06-07, 05:56 PM
Pearlpower
Pearlpower's Avatar
Thanks. Looks good.
I ordered up the exhaust components today after finding some tips to match my taste. I looked at the 4Runner kits out there from TRD and Magnaflow but decided to just put together my own as fitment was a concern and the Magnaflow cat back system has a bothersome drone that many have complained about.
Went with 2 qty 4.5"x3.5" oval exhaust tips and a Magnaflow 14586 muffler as many on the 4runner/Tundra forums have run with success. Pipes are going straight out the back vs the side as pictured. My exhaust guy had the GX on the lift today to check out the pipe routing. No problems.
Will post next week when everything should be on along with some other mods.
Old 04-06-07, 06:23 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
No pics..
Pearl those tips look nice..
Old 04-06-07, 09:32 PM
GS3Tek
Forum Moderator
GS3Tek's Avatar
I don't see any pictures RX900.
Awesome Pearl, keep us updated
Old 04-06-07, 10:00 PM
purplehazek4
purplehazek4's Avatar
Random pic i had saved...
Old 04-06-07, 11:45 PM
milky
milky's Avatar
wow those tips really compliment the suv. Nice.
Old 04-07-07, 07:34 AM
Pearlpower
Pearlpower's Avatar
I like it; looks good! I believe the tips I am receiving are a tad larger than those.
Quick Reply: Exhaust Tip PICS?
