Power Steering pressure switch code P0552
Has anyone encountered this code on their vehicle? I attached a diagnostic tool to my GX and came up with a code P0552. The symptoms I am experiencing are, periodically the car will not start out in first gear. It feels like it’s in second or third gear when moving from a stopped position. When the car is underway after about a few seconds, it will select the appropriate gear.
Another code that came up on the diagnostic tool was, C1201 (Brake Boost Sensor Circuit Range/Performance).
I recently had my brakes serviced about two weeks ago and this issue with the transmission started right after the brake service. Could it be the brake sensor?
Super Moderator
This is all I am seeing in FSM for P0552
C1201
I see you had this C1201 a number of years back
https://www.clublexus.com/forums/gx-...l#post10693149
C1201
