Down hill switch on console
Old 03-17-17, 10:11 PM
mrblister
mrblister's Avatar
Default Down hill switch on console
I forgot if the down hill assist switch mounted on the center console next to the shifter is it illuminated I know it lights up green on the dash instrument cluster when switched on but does the switch it self illuminate and if so how do I get to the bulb.
Old 03-18-17, 08:31 AM
chiph9
chiph9's Avatar
It does light up. You can use a plastic trim tool to pop the switch out. The connector & wires behind it are somewhat short so reconnection might be a challenge after the bulb swap.
You want bulb 84988J and you just use a small flat-head screwdriver to unscrew it from the side of the switch body.
http://www.lexussouthatlantaparts.com/showAssembly.aspx?ukey_assembly=786374&ukey_make=1082&ukey_model=15663&modelYear=2004&ukey_category=21749&ukey_driveLine=8091&ukey_trimLevel=19100
Chip H.
mrblister (03-18-17)
Old 03-18-17, 01:32 PM
mrblister
mrblister's Avatar
Thanks for your perfect instructions and link
Buddy
http://www.lexussouthatlantaparts.co...rimLevel=19100
Thanks for your perfect Instructions and link you mad it really easy .
Many Thanks
Chip H.
Old 03-18-17, 05:23 PM
chiph9
chiph9's Avatar
Whoops - just went and looked at it in my car. It does NOT come out from the top like other switches. You will need to remove the "wood" panel and get to it from underneath.
Use your trim tool and remove the plastic wings, starting back at the storage bin. The first part of this video shows how:
Then lift up on the shifter panel, from the back by the storage bin. The rest will be obvious (clips/screws)
Chip H.
johnnylt
08-06-18 10:04 AM
Threxx
11-28-16 05:25 PM
schack
11-19-14 07:40 AM
gserep1
02-02-05 09:49 AM
Quick Reply: Down hill switch on console
