"Rumble strip" sensation
Noticed this for the 1st time last week, initially wondered if I had a separated tread on a tire or something. Did some more testing, and some googling, and came across a thread on T4R.org where lots of owners with our drivetrain, as well as the V6 version were having the same issues:
http://www.toyota-4runner.org/4th-ge...ion-issue.html
Here's what's happening, which wasn't obvious until I found the thread and paid attention to confirm the conditions were the same in my case. Moderate acceleration around the 80km/h/50mph point where the trans shift to 5th, there's a sensation in the truck like you're riding on a rumble strip on the side of the road, a vibration you can feel through the pedals moreso than the steering wheel though. My wife claims to have experienced it at lower speeds, presumably at the 3-4 shift point, but I've been unable to replicate this so far.
The consensus seems to be it's an issue with the torque convertor, as it locks up only in 4th and 5th gears so you won't see it in the lower gears. I did a series of 3 drain & fills on the transmission last year, using Toyota WS fluid, so I can't see how further drain & fills would have any effect for me. Some have used a product called "shudder fix" with success, but I'm hesitant to put stuff like that in there as by all accounts the trans if very sensitive to things like fluid type, and level as it is.
Anyone else have similar issues, or insight?
Since I'm an Infiniti tech, I know the CVT's in our JX35's and QX60's are terrible for shuddering. Last year I was putting new trans' in left and right to fix them per Infiniti, only to have the new one do the same thing. They "seemed" to have worked it out with a software update, maybe there's something similar with Lexus?
Thanks for the input! In my reading on this "shudder fix" product, it's not compatible with CVT trans, so that's not going to be an option for your customers.
I wonder how much Lexus would ding me to hook the truck up and see if there's any updates available for the TCM? Might be worth exploring before putting any additives in the trans.
FWIW, my wife hasn't reported any issues for the last few days, and I don't get the impression this is at all time sensitive to get resolved, in that seems to be mostly annoying with no risk of doing damage from driving with the issue.
We didn't have any "rumble strip" noises for a few days, then had a CV joint fail, so I'm mid-way through replacing both front axles. Hoping the noise doesn't return once I'm back on the road, and it was just a fluke.
Interesting.. Although for me, my CVs/Boots are in tip top shape.
“New” 05 with same issue...trying flush
Recently purchased an 05 with 150K. Having the same issue, although rarely. Tomorrow, she’s going in for all fluids (oil, diffs, transfer case, tranny). I’ll report back on if this makes a difference in reducing/eliminating the shudder.
Long term update: rumble strip sensation hasn't presented in years. I can't remember what I did before it stopped though.
I changed the trans fluid at some point, PROBABLY after this issue came up as I don't see where I mentioned it in my earlier posts.
Lextazy (01-08-20)
Short term update...problem fixed!
After having transmission flushed/serviced this morning (as well as all other fluids...oil, diffs, transfer case), the shudder problem seems to have disappeared. On the way to the shop this morning I experienced it at least a few times, but on the way from the shop I could not get it to do it. So...here’s to it being fixed (knocking on wood now)!
I'm having my transmission flushed while typing. I was afraid of doing it as the first time I had the fluid drained and filled was at 165k and the fluid was not that fresh... I've heard that flushing can cause damages. But some people on FB GXOR group, including people working at Lexus dealerships and owning the same vehicle, said that they fixed a lot of GXs that way - by flushing the trans.
Another method I found was to drain and fill about 4 times with 2 weeks in intervals. And people who done the flushing told me that either flush one time or do 4-5 drain and fill. Some people add shudder fix additive, but I don't trust that. In my opinion, the fluid should be just the fluid and nothing else.
Sooo, hopefully, the trans flush will resolve my problem and it will not cause any damages to the tranny.
It's "Power Flushing" with a machine that has it's own high pressure pump that can damage things, drain & fills or using the transmission's own internal pump to move fluid should be very low risk for causing damages. Fresh fluid is always better than old, burnt fluid.
Lextazy (01-08-20)
I didn't know the difference in the way of flushing. Hopefully, dealerships do not use power flushing
Done the flushing, not by a machine with cleaners etc.
Still have the shudder, but not as bad as it used to be. Hopefully, it will go completely away after a while. If not, I'll just have to live with it. Tired of trying to fix it.
Thank you all for your help. Will definitely update if the problem is gone completely.
IanB2 (01-08-20)
jwigley
RX - 3rd Gen (2010-2015)
19
01-21-15 08:08 PM
