GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Odd Issue: Interior Lights and Door Ajar Light comes on During Acceleration
Old 01-14-16, 09:56 PM
mswtoyota
mswtoyota's Avatar
Originally Posted by LexRex
I wonder if it's possible to adjust the catch on the door so the door closes slightly tighter...?
I agree. I would try loosening the two screws and moving the catch (69451A on the diagram Dashome posted) toward the front of the vehicle 1/8" before buying a switch.
Old 01-15-16, 07:58 AM
IanB2
IanB2's Avatar
I'm going to look into this tonight, I'll post back with my results.
Old 01-15-16, 08:12 AM
chiph9
chiph9's Avatar
Be sure to run the hose on the roof to make sure you don't end up with any water leaks after adjusting the catch.
You might want to put some silicone spray on the seals to loosen them up some (fill any gap).
Chip H.
Old 01-15-16, 09:31 AM
IanB2
IanB2's Avatar
Chip H.
I'd be adjusting the catch so the door closes tighter, so the sensor is depressed further when the door is closed. I wouldn't expect any gaps, the seal should be squished tighter, unless I'm missing what you're saying.
In any event, it's -20C (-4F) here today, garden hoses have been packed away months ago, lol. I'd need a trip to the carwash (which it could use anyways) to test for leaks. I still don't see why it should be a concern though.
Old 01-15-16, 12:46 PM
chiph9
chiph9's Avatar
No, you're right. You're adjusting the catch tighter to depress the switch further. My bad.
70F in Austin today. Not quite beach weather, but I'll take it.
Chip H.
Old 01-15-16, 09:15 PM
IanB2
IanB2's Avatar
Well, the latch striker is mounted with beveled screws and holes in the mounting plate to the body, so no real adjustment available there. None of the various stoppers are adjustable on the door or the body. As a temporary measure, I loosened the bolt on the sensor, and stuck a washer behind it at the top, and tightened it back down. Serves to push the sensor out from the body, meaning it will get depressed when closed further, and should fix the issue. I don't like it long term as there's a gap where moisture could get into the body when it rains, carwash, etc. I think it's new sensor time. Needs to be ordered in says the dealer.
Old 01-19-16, 08:14 PM
IanB2
IanB2's Avatar
I ordered a new sensor, I'll update once I pick it up from the border, get it installed, and leave the truck out for a few cold nights.
Old 01-26-16, 07:47 AM
Lextech43
Lextech43's Avatar
I had the same problem with mine last year. I replaced the stopper and it has been ok since. I don't know if it gets crushed over time and doesn't push the sensor far enough. I put them side by side before replacing it and they looked the same.
Old 01-26-16, 08:39 AM
IanB2
IanB2's Avatar
So you replaced the stopper, and not the sensor? Strange that this fixed your issue, given that they looked the same upon side by side inspection, but whatever works.
Old 02-07-16, 08:10 PM
IanB2
IanB2's Avatar
Got the sensor, installed it today, it's a 2 min affair. Remove the 1 x 10mm bolt, pop the panel out of the rear driver side corner of the interior plastics, and reach in and unplug the sensor harness, the pinch tab is on the bottom edge. Plug in the new sensor, tighten the bolt, and you're done.
It's not brutal cold here right now, which I'm cool with, but it means testing is weather dependent as it had to be -20C or worse before this was an issue.
Old 02-10-16, 12:11 PM
180ls1
180ls1's Avatar
Had the same issue. I whacked the latch that is mounted to the vehicle (not the door) several times with a large hammer to push it in a little further. Wazinga! It worked!
sinoma (11-15-19)
Old 02-11-16, 07:59 AM
IanB2
IanB2's Avatar
Hmm, that's another way to skin this cat I suppose.
shsaing
12-17-18 05:39 PM
waynedog
08-29-12 11:14 PM
jbrandon20
RX - 3rd Gen (2010-2015)
07-01-12 09:51 AM
fordsvtmfl
01-07-11 05:38 AM
flyboicus
07-27-06 12:36 PM
Quick Reply: Odd Issue: Interior Lights and Door Ajar Light comes on During Acceleration
