Removing subwoofer grill
Old 08-27-13, 08:44 AM
pink
pink's Avatar
Default Removing subwoofer grill
So have I have solved all my problems on this forum myself. Thanks to all that helped out. Now is there anyway to remove the subwoofer grill without taking out the whole panel on a 03 GX 470?? I think it's just ripped and might be able to fix it with some nailpolish.
Old 08-30-13, 12:11 PM
rj4510
rj4510's Avatar
I just took mine off and put it back together again. There's no way to remove the grill from the front and the woofer is somewhat offset, so you would likely not be able to repair it in place. To save you some time, here is the part number you need to re-foam the suround: FSK-6BT-1 available from SimplySpeakers.com.
The cost is $20 and fits perfectly, but the outer edge needs to be cut down to half the width, as the recessed basket prevents it from fitting. I just used a pen to mark all the way around it and a pair of scissors to trim it down. Turn out great and sounds good as new.
Look here for more info:
https://www.clublexus.com/forums/gx-...ml#post8116434
Old 05-03-14, 06:00 AM
GaryRama
GaryRama's Avatar
This issue is very frustrating for me. I'm trying to replace the sub on a LX 470 without costing a million dollars.
Old 05-03-14, 06:28 AM
rj4510
rj4510's Avatar
If you chose to repair it, I'm pretty sure the link above was for an LX as well.
Old 05-03-14, 08:54 AM
Lmcqueen
Lmcqueen's Avatar
I refoamed my 2GS with the kit from simply speakers, sounds brand new.
I thought about switching the sub with the aftermarket one, etc but I figured the extra $$ will be spent elsewhere as the sub fix cost me like 20$, and about 2 hours. I read someone dapped in some hot glue to fix the foam, just removing the grill only but I think that's just a band aid fix. My old foam was a toast, all the way around.
nysupraman
IS F (2008-2014)
36
02-12-17 08:40 PM
dougm213
12-02-14 05:45 AM
JH48
12-18-12 01:11 AM
OutkastGS3
02-20-09 09:50 AM
Styx
IS - 1st Gen (2001-2005)
07-17-04 11:35 AM
Quick Reply: Removing subwoofer grill
