2007 Lexus GS 350 Engine Noise
Old 07-15-14, 06:57 PM
Shrewd
Shrewd's Avatar
Default 2007 Lexus GS 350 Engine Noise
Hi All,
I just bought a Lexus and discovered it has a sound from the engine. It sounds exactly like this video. The poster never mentioned how he fixed it. Can you guys give me some pointers.
Old 07-15-14, 08:02 PM
snkepit
snkepit's Avatar
Man that's not a good sound! Sounds like a engine rod knock
Old 07-15-14, 10:51 PM
warandcar
warandcar's Avatar
when did lexus make a diesel?
Old 04-10-15, 06:54 PM
edsones350
edsones350's Avatar
Hi, Im having the same problem too with my 2007 es350 UL. I complained it to my lexus dealer and they diagnose it as the camshaft is loose that's why the engine is loosing pressure. They replaced the camshaft. But after, they noise was still there. Pretty disappointed with the diagnose they made and nothing changed with the engine. The sound was still there. It happens during the first 15min until it reaches the running temp and quiet down a little bit. Is it possible that the engine needs some valve adjustments?
Old 04-10-15, 09:08 PM
SILENTM
SILENTM's Avatar
Sounds like the variable valve timing cam gears, any faults stored.
Old 06-02-15, 09:51 PM
edsones350
edsones350's Avatar
Hi, no check engine light. Lexus replaced the vvti cam gears already for me but still... the sound im complaining about is still there. they heard it and they said its normal cause the engine is an aluminum block expands and contracts on temperature. But to me seems like its more to that... it is really loud when you drive it during cold start.
Old 06-03-15, 07:49 AM
burny
burny's Avatar
that is the cam gear rattling. That is not normal. They need to fix it again from the recall
Jjmuckley
02-17-22 06:32 AM
Salazar
RC - 1st Gen (2015-present)
17
05-12-21 04:36 PM
Cargrub
ES - 6th Gen (2013-2018)
07-08-19 11:46 AM
is350lexo
Performance
02-20-15 05:50 PM
jimmv28
05-16-10 12:59 PM
Quick Reply: 2007 Lexus GS 350 Engine Noise
