I've noticed intermittently (but seems to getting more frequent) a rubbing noise from the front end at speeds below 10mph. It seems to only happen only after reversing. The noise is on a rotation. Almost sounds like putting a baseball card on the spokes of your bike. As you pick up speed the noise goes away & does not occur for the remainder of the trip. Spunds like its coming from the left wheel well. Any ideas? Thanks
Stock Tires. No rub marks. Only happens when going straight under 10mph. And if it does happen faster than 10mph, I cant hear it.
Had brakes & rotors but on about 4 months ago. Althought I don't hear this noise when braking.
If the noise goes away once you apply the brakes then that sounds like its coming from your front brakes. Sounds like maybe it is the disc front brake shield rubbing the rotor. When they installed the front brakes they may have tweaked it on accident
The noise goes away without using the brakes. Usually goes away after about 15 seconds after starting. Im starting to think its not from the wheel. Happens after cold starts.
Nah, it doesn't sound like that. I took it to the dealer see what they come up with. Only happens under 10mph on cold starts. Last for about 10-15 seconds then goes away.
