high HC at idle
Old 04-21-14, 10:39 PM
neo1054
neo1054's Avatar
Default high HC at idle
I did not pass smog due to a high HC at idle ( 177 at 650 rpm) no check engine light or codes posted I've changed both o2 sensors on bank 1 new denso spark plugs new air filter oil change cleaned the air box checked for leaks on all vacuum lines and hoses and still high HC any ideas everything else is fine the HC is normal when at 2500 rpm my visuals and equipment always pass. Can this be due to the customer support program with misfired for my 06 gs300 that is notorious plz help
Old 04-22-14, 11:24 AM
XxGoKoUxX
XxGoKoUxX's Avatar
http://www.smogtips.com/failed-high-hydrocarbons-HC.cfm
I've never really read into high HC, your next goal might be to check your injectors to see if it's running in tip top shape.
Ultimately, you may also need to run a compression check too, to make sure all 6 cylinders are within spec.
GL!
Old 04-22-14, 05:53 PM
neo1054
neo1054's Avatar
Default high hc at idle
GL!
cool thanks I will look into that see it that might be a problem but looks like its dealership time
Old 04-22-14, 08:04 PM
XxGoKoUxX
XxGoKoUxX's Avatar
Yeah, I really wish you the best of luck. Kinda wish I had more experience with these smog tests. FL doesn't have'em
TechGreek
Performance & Maintenance
41
03-20-19 07:58 AM
STREETGS
10-04-16 03:30 PM
TLDriver
02-23-10 04:53 PM
MT Photo
14
07-11-08 02:16 PM
envyno1
03-15-08 08:33 PM
Quick Reply: high HC at idle
