Swapping Navigation DVD Player Unit
How much effort is this? Couldn't find a DIY.
Basically, my navigation won't read the disk anymore and I'm looking at replacing it with a used one.
Thanks.
Thanks.
From looking at the pictures it doesn't seem hard but you may want the diagrams that show how to remove all the panels.
1. DISCONNECT CABLE FROM NEGATIVE BATTERY TERMINAL
CAUTION:
Wait at least 90 seconds after disconnecting the cable from the negative (-) battery terminal to prevent airbag and seat belt pretensioner activation.
2. REMOVE FRONT CONSOLE UPPER PANEL GARNISH
3. REMOVE CONSOLE UPPER PANEL ASSEMBLY
4. REMOVE INSTRUMENT PANEL FINISH PANEL END RH
5. REMOVE FRONT DOOR SCUFF PLATE RH
6. REMOVE FRONT DOOR OPENING TRIM COVER RH
7. REMOVE INSTRUMENT SIDE PANEL RH
8. REMOVE NO. 2 INSTRUMENT PANEL UNDER COVER SUB-ASSEMBLY
9. REMOVE FRONT PASSENGER SIDE KNEE AIRBAG ASSEMBLY
10. REMOVE GLOVE COMPARTMENT DOOR SUB-ASSEMBLY
11. REMOVE NAVIGATION ECU WITH DISC PLAYER BRACKET
(a) Disconnect the connectors.
(b) Remove the 3 bolts and navigation ECU.
12. REMOVE NO. 2 DISC PLAYER BRACKET
(a) Remove the 2 screws and bracket.
13. REMOVE NO. 1 DISC PLAYER BRACKET
14. REMOVE NAVIGATION ECU
Any tips on fixing the "unable to read dvd" error code prior to replacing? I've got a cleaner disc, but not sure it actually gets to the cleaning brushes part of the cd when I play the disc. Also read that it's probably not dirt, but the laser motor itself.
Anyways, any suggestions before I replace hardware? Was working before I shipped the car back to the states, but it did have a few cases here and there where it acted up prior so it was probably on its way out.
aldoubi
10-18-10 05:18 AM
