GS 350 Engine Block Heater
I was wondering if any of you guys have installed an engine block heater on your engines. Also, has anybody tried one or more of the following; Magnetic heater, Oil Dipstick Heater, Space Heater and whatever else anybody has done.
How does our vehicle perform as far as starting and driving in extreme cold temperatures, do you heat the transmission pan, rear diff?
Any sort of cold weather input would be great.
Thank you.
Thank you.
How cold does it really get in WA? Most you need to worry about is your battery really.... Radiator fluid, if properly mixed, shouldn't freeze over in your engine and u should be fine
It has already gotten to -18 ambient a couple times in these areas. It's not odd to get down to -30 ambient. With wind chill it gets to -60 quite often in the Montana, North Dakota plains.
