Personal Swimming Pool
so i got into my car last night and i noticed all the windows were fogged up but i havent been in the car... so i drove home and pulled my backpack outta my back seat floor to find it wet... OH NO here we go again with the a/c evap grommet. same thing happened in my is250... but now i can hear water in the padding under the capert... goes "squish squash" how would i absorb the water? anyone else delt with the evap line being clogged?
Could be an evap clogged or the sunroof drain tubes. But if you said the car was sitting I would put my money on the sunroof not draining.
Heres is a way to test it, open the sunroof. Grab a bottle of water and around the sunroof frame should be valley channels for water, and on front corners (driver and pass side) should be a drainage hole. Pour the bottle of water into that channel to see if the drains are draining. If the drains are clogged what you can do is grab a electrical wire, preferably a coaxial cable with the wire inside and snake that down each hole.
1: The best way to remove water under the carpeting is the remove the carpet from the car and let it air dry, if its not molded up.
2: Not as effective as 1 but you can remove the plastic door sills, and lift up the carpet and use a shop vac to suck the water out.
3: Another trick use a shop vac and force the head into the carpet, then put the cars heater turned up and on the floor.
was the a/c evap grommet. apparently was the same issue as my is250. the evap drain line is covered by a grommet that just was a bad designed item to begin with. theres a TSB out there to pull it off but dont let the dealers fool you. I look it in to lexus and they told me that i had to pull the dash and drill into the evap and i was skeptical. so i went and looked for the TSB and there it was stating that i just had to pull off the grommet with a long nose pliers.
jmeade
09-21-18 10:01 AM
