Rusting Brake Drums (or Metal Cover)
Old 11-07-12, 11:03 AM
maficrock
maficrock's Avatar
Default Rusting Brake Drums (or Metal Cover)
Reaching out to GS folks who may be encountering similar problem. I have a 2006 GS430 in which the rear brake drums? (or outer metal cover) has rusted. I have the OEM Lexus wheels and the problem is it is very noticeable and from an appearance standpoint is "ugly" to look at.
Does anyone know if this part can be replaced and if so what the expense is? I would think you would be able to powder coat the part as well, but seems this would be a hassle to do.
Any feedback and/or suggestions would be great. Thanks
Old 11-07-12, 12:03 PM
worker
worker's Avatar
Everything can be replace. Pics would help.
DW40 is your answer. Just give it a bit more breaking distance when you do drive.
Old 11-07-12, 12:16 PM
maficrock
maficrock's Avatar
Worker - Thanks! I can take a picture and include it. It's on both rear brakes. Sounds like a solution may be to remove the tires and just clean them off? Maybe use steel wool and apply WD40? thanks
Old 11-07-12, 12:22 PM
IXI187IXI
IXI187IXI's Avatar
if its on the brakes, its probably just a little surface rust staining like you get on your rotors after the car has sat during a rain.
Old 11-07-12, 12:58 PM
worker
worker's Avatar
^ that's what I think too. But a pic worth a thousand words.
I have the '06 GS430 too.
Old 12-27-12, 06:42 AM
snayger
snayger's Avatar
mine does that also, 07 GS350
Old 12-27-12, 06:58 AM
Simmsled
Simmsled's Avatar
DO NOT USE WD40 on your brakes. It can contaminate the brake pads and lead to brake failure.
New rotors... and pads solve it. It is basically a brake job to do it right. Good rotors with a coating on the hats, like OEM or Adam's Rotors. Adams will coat the hats properly and it lasts. More than a few friends of mine with GTIs had them with good results.
Old 12-27-12, 09:16 AM
ibidu1
ibidu1's Avatar
scuff them up and paint them if they look bad, you could use a color that matches the factories coating.
The proper way is to take them off and send them to get anodized coated.
Old 12-28-12, 10:49 AM
adamsrotors
Former Sponsor
adamsrotors's Avatar
our rotors (and drums) are ALWAYS coated in zinc to prevent what you are explaining.
we have complimentary silver or upgradable black or gold.
visit our site for more info on our stuff!
stephenmat
03-07-18 07:18 PM
nielboy
05-04-14 02:19 PM
papachulo
Suspension and Brakes
05-04-09 07:00 AM
iKenn
02-19-08 07:29 AM
DesertGS
01-05-06 09:12 AM
Quick Reply: Rusting Brake Drums (or Metal Cover)
