GS 350 DRL BULB? 9005 or 9006?
Old 07-13-11, 07:45 AM
jusdach
jusdach's Avatar
Default GS 350 DRL BULB? 9005 or 9006?
I'd like to change the yellow LED bulb that's runs as the DRL on my '07 GS 350. Is that bulb the 9005 High Beam or the 9006 Fog? I know there's a lot of posts on here about this but I've seen it answered both ways.
Old 07-13-11, 08:49 AM
HamBurglar
HamBurglar's Avatar
Your DRL and High beams are the same bulb 9005. The DRL is just the high beam running at a low power. If you are trying to change it due to the color then you're going to need to get a DRL LED kit but you will lose your high beams.
There is also a 194 bulb in the high beam housing that turns on when you use your low beams. That can be changed out to another halogen or LED if you want.
Old 07-13-11, 08:58 AM
jusdach
jusdach's Avatar
That's what I thought, but couldn't I just swap the OE 9005 for a Philips 5000k bulb and get a whiter output without using a kit or module? Thanks for your help HamBurglar but has anyone successfully tried this without a kit (i.e. no error lights or bulb flicker)?
Old 07-13-11, 09:13 AM
HamBurglar
HamBurglar's Avatar
Good question haven't seen anyone try that but thinking about it I figure it will probably be the same since it's still running the same output.
Since you are swapping the OE Halogen for another Halogen bulb then you wouldn't need a kit or module.
Another thought, you could have the dealership turn off your DRL and you would still have your High beams.
Old 07-13-11, 12:47 PM
jtrue28
jtrue28's Avatar
I'm not sure there's any halogen bulb you can buy that will be more white. the problem is, it's the high beam running at half the power. I've tried 7500K Nokya bulbs before, but they still look yellow...not as bad, but they're not HID quality by any means.
Old 07-13-11, 01:40 PM
j0emama
j0emama's Avatar
Just FYI I tried this already. Swapped it out with both Phillips Crystal Vision and Sylvania SilverStar Ultra (OEM is Sylvania ECO), with crappy results. The difference is not even noticeable. The bulbs looks so much nicer and cleaner with bluish housing, but it's just as yellow as stock once they light up.
This is the only damn light in the entire car I haven't been able to change and it's killing me! Guess I'll just have to keep the lights on in the daytime too!
Old 07-20-11, 03:54 PM
Shibumi1
Shibumi1's Avatar
chk ur personal setting options (dealer adjustable) i went the the dealer an had them turn off my drl's so now they're jus my high beams.. then i rewired my 8k hid fogs as my drl's but i drive an LS so it maybe different..
Old 03-24-13, 09:02 PM
smilepak
smilepak's Avatar
Anyone tried this?
Sylvania 9005 SZ SilverStar zXe High Performance Halogen Headlight Bulb (High Beam), (Pack of 2) : Amazon.com : Automotive Sylvania 9005 SZ SilverStar zXe High Performance Halogen Headlight Bulb (High Beam), (Pack of 2) : Amazon.com : Automotive
to replace the Day Light / High Beam?
Ken167
08-26-16 12:05 PM
KeleIS250
02-23-12 08:01 AM
KevMMA
Lighting
10-03-08 02:55 PM
dRo15
01-12-08 05:31 PM
Quick Reply: GS 350 DRL BULB? 9005 or 9006?
